[GRASS-user] The r.gmtg moduel for MODFLOW.
Markus Neteler neteler at itc.it
Fri May 4 06:03:30 EDT 2007
Antonio Gennarini wrote on 05/03/2007 10:17 AM:
> Hi
> I just downloaded the r.gmtg module from
> http://www.valledemexico.ambitiouslemon.com/gwmodelling.html for MODFLOW
> integration within GRASS. However, I don't seem to understand how to
> compile this module. I seem to understand that I should be using Gmake,
If 'gmake' is asked, this indicates that the module was developed for
GRASS 4 or GRASS 5.
GRASS 6 is using the standard 'make'.
So you would need to write a new Makefile and most likely do other
changes in the source code to update it to GRASS 6.
> however, Debian doesn't seem to have such a package ...
> What string should a give the compiler and what development packages
> should be installed on my machine.
> The above site is lacking documentation so I thought that some one in
> the list might have had success with this in the past. I really keen to
> get up and running with this
Please contact the author for this.
Markus
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
