[GRASS-user] Again: Problem with WMS-Services
    Craig Leat
    Craig at pid.co.za
    Tue May  8 09:13:31 EDT 2007
Hi Christian
Please check the following and post your findings:
1.  Do you have write permissions in the directory "/home/uleopold/tmp"?
2.  Is the program wget working on its own? Try retrieving some file across
the internet to verify your proxy server configuration, if required, and the
like are correct.
3.  Check the directory "/home/uleopold/tmp" to see if anything has been
downloaded.
With the above information someone may be able to help further. I am afraid
that this is as much help as I can offer.
Best regards
Craig Leat.
> Message: 4
> Date: Mon, 07 May 2007 17:00:23 +0200
> From: Christian Braun <christian.braun at tudor.lu>
> Subject: [GRASS-user] Again: Problem with WMS-Services
> To: grassuser at grass.itc.it
> Message-ID: <1178550023.15183.1.camel at t60.esch.tudor.lu>
> Content-Type: text/plain
> Hi list members,
> I wrote to the list a few weeks ago with no answers to my problem.
> So again here is my problem again:
> I have a problem importing WMS-Services into GRASS. Here is the command
> and the description of the error I got:
> ##The command which has been issued on grass command line
> r.in.wms -d -p output=DEM_WMS
> mapserver=http://10.3.1.12/cgi-bin/mapserv?map=/data/umn/pmapper-
> 3.0.1/config/default/demo_wms.map
> layers=DEM_WMS srs=EPSG:4326 format=geotiff wmsquery=version=1.1.1
> maxcols=1024 maxrows=1024 folder=/home/uleopold/tmp 'wgetoptions=-c -t 5
> --user-agent=MSIE5.5' method=nearest v=1 --overwrite
> ##The error message:
> wms.download  'requestfile=/home/uleopold/tmp/DEM_WMS_.wget'
> 'wgetoptions=-c -t 5 --user-agent=MSIE5.5'
> Downloading tiles
> cat: /home/uleopold/tmp/DEM_WMS_.wget: No such file or directory
> All tiles downloaded successfully
> r.in.gdalwarp  -c -p 'output=DEM_WMS' 'method=nearest' 's_srs=EPSG:4326'
> ERROR: Required parameter <input> not set:
>     (Raster file or files to be imported. If multiple files are
> specified they will be patched together.).
> In software like QGIS and ArcGIS the WMS-Service is working very well.
> It seems that there is aproblem with the input data that is piped to
> gdalwarp.
> Any ideas...?
> cheers
> Christian
