[GRASS-user] problem with g.remove
Jarekj Jasiewicz
jarekj at amu.edu.pl
Tue May 8 16:43:56 EDT 2007
Hi
There is the problem with g.remove (in gui dialog_box) for vector files
(cvs from sunday, maybe fixed now)
g.remove vect=azp_p1 at azp
I recive:
Removing vector <azp_p1 at azp>
Cannot open directory
'/home/jarekj/grassdata/srtm92/azp/vector/azp_p1 at azp' <<see here>>
Cannot open directory '/home/jarekj/grassdata/srtm92/azp/vector/azp_p1 at azp'
couldn't be removed
couldn't be removed
<azp_p1 at azp> nothing removed
of course directory azp_p1 at azp didn't exist (dir (azp_p1 exist)
and when I use g.remove vect=azp_p1 all works fine but is little
problematic with multiple files
ragards
Jarek
BTW: why most of the massage (most of I use) are doubled (as above)
