[GRASS-user] RGB to Grayscale
Markus Neteler neteler at itc.it
Sat May 12 13:21:42 EDT 2007
On Thu, May 10, 2007 at 06:14:31PM +0100, Glynn Clements wrote:
> To convert to greyscale, you would normally just use the intensity.
> Also, note that the "intensity" map generated by i.rgb.his is
> completely bogus.
Should be reported as bug then/fixed?
Markus
