[GRASS-user] gdal - r.in.onearth
Hamish
hamish_nospam at yahoo.com
Tue May 15 04:58:57 EDT 2007
> Hamish:
> > > G63> g.region -b
> > > pj_transform() failed
> > > cause: failed to load NAD27-83 correction file
> > > ERROR: Error in pj_do_proj (projection of input coordinate pair)
> > > that doesn't look good.
> Markus:
> > (as you will know)
> > It indicates that
> > http://proj.maptools.org/
> > -> proj-datumgrid-1.3.zip
> > ftp://ftp.remotesensing.org/proj/proj-datumgrid-1.3.zip
> > wasn't expanded in nad/ before compiling proj4.
Hamish:
> The error was because I had changed the region to match a XY raster,
> well outside of the location's nad grid file coverage.
this is bug #4028 by the way.
https://intevation.de/rt/webrt?serial_num=4028
Hamish
