[GRASS-user] How can i open vector files having dgn format
Nitin
grasschoper at rediffmail.com
Fri May 18 08:39:15 EDT 2007
hello pawan,
OGR is not capable of finding geo refrence information about DGN files.
DGN being a properitry format is not revealed completely specially type56 element( contains datum and projection information). I think this is main reason for this.
You will be able to view map elements without any georefrence informatio in grass or QGis. You can try to superimpose it over other maps by providing end coordinates. Someone might help on this matter.
If you finds anyways , keep us also updated.
nitin
On Thu, 17 May 2007 Pawan Joshi wrote :
>Hello all ,,
> How can i open vector files having dgn format. when i m using "v.in.org -o"
>It is running without any error message but when i m displaying the map there is not any relevant display according to the Geo-reference. The map region belong to 22N,21N,76E,77E. but there is no data in that region but when i select the whole word as a region for that dgn vector map i have a number of lines and circle as a data on using d.vect ................
>What is the proper command OR grass does not support it well. as i have already send the same problem, please don't direct your reply to some other URL.
> That is having the information of supported vector format for Grass6.2
>Thanks
>Pawan Joshi
>Sick sense of humor? Visit Yahoo! TV's Comedy with an Edge to see what's on, when.
>_______________________________________________
>grassuser mailing list
>grassuser at grass.itc.it
>http://grass.itc.it/mailman/listinfo/grassuser
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070518/068d5d4a/attachment.html
