[GRASS-user] points in polygon query
    Moritz Lennert
    mlennert at club.worldonline.be
    Mon May 21 04:10:04 EDT 2007
On 21/05/07 09:39, Hamish wrote:
> Stefano Costa wrote:
>> for i in $areas; do
>>    count=$( db.select -c points_tmp sql="select cat_area from points_tmp" | grep -c $i)
> You might want to make the ending "grep -c $i" a bit more specific,
> as you don't want to count "10,11,Site 1" in a where="cat = 1" grep count.
> As written it could lead to buggy results.
Can't you do the selection directly in sql:
count=`db.select -c points_tmp sql="select count(*) from points_tmp
where cat_area=$i"`
  (but no idea if this is faster)
Moritz
