[GRASS-user] points in polygon query
Maciej Sieczka
tutey at o2.pl
Mon May 21 14:41:02 EDT 2007
Hamish wrote:
> Stefano Costa wrote:
> re speed-
>> echo "UPDATE $output SET count = $count WHERE cat = $i" | db.execute
> instead of running db.execute at every iteration in your loop, >> append
> the SQL command to a g.tempfile (end each line with a ';'), then once
> the for loops are done, run db.execute once with the input=$tempfile.
> then the script will be much much faster I think.
Last time I checked that it was circa 20 (twenty) times faster for me.
Sorry no exact benchmarks.
Maciek
