[GRASS-user] problems with r.cost
Paul Haverkamp
pjhav at ucdavis.edu
Wed May 23 13:44:44 EDT 2007
Hi Hamish,
Thanks for getting back to me.
I am using 6.2.1, and g.region -p gives the info:
projection: 1 (UTM)
zone: 10
datum: nad83
ellipsoid: grs80
north: 4269999
south: 4180119
west: 598614
east: 651978
nsres: 3
ewres: 3
rows: 29960
cols: 17788
cells: 532928480
I'm trying to run with the resolution of 3m, but when I change it to 30m,
there isn't a problem. Using much smaller regions doesn't seem to have
this problem. So is the file just too large at too small of a resolution?
I'll try to run Spearfish and let you know.
thanks again,
paul
> Paul Haverkamp wrote:
> > i'm a very new user to grass and am using r.cost in grass6.2. i'm
> > trying to run a cost analysis on my raster and having some difficulty.
> which version of 6.2? 6.2.0 or 6.2.1?
> how big is your region? (g.region -p) Does it happen if you make the
> region smaller or adjust the resolution?
> can you reproduce it using the Spearfish demo dataset? if so, can you
> post instructions with that in the grass bug tracker?
> thanks,
> Hamish
