[GRASS-user] problems with r.cost
Jerry Nelson
gnelson at uiuc.edu
Wed May 23 14:06:40 EDT 2007
One thing to try if you haven't already is to recompile grass with large
file support included. I don't know why that's not done automatically but
apparently it isn't.
Another, if region size is really the issue and you are a C programmer or
know one, is to modify the make file of a grass add-on called r.terracost.
It was written as a CS project at Bowdoin at a time when grass was at
version 5.3. With the move to version 6, the make process changed slightly.
The r.terracost files are available at
http://www.bowdoin.edu/~ltoma/research.html
Or you could get grass5.3 and run r.terracost with it.
Regards, Jerry
-----Original Message-----
From: grassuser-bounces at grass.itc.it [mailto:grassuser-bounces at grass.itc.it]
On Behalf Of Paul Haverkamp
Sent: Wednesday, May 23, 2007 12:45 PM
To: Hamish
Cc: grassuser at grass.itc.it
Subject: Re: [GRASS-user] problems with r.cost
Hi Hamish,
Thanks for getting back to me.
I am using 6.2.1, and g.region -p gives the info:
projection: 1 (UTM)
zone: 10
datum: nad83
ellipsoid: grs80
north: 4269999
south: 4180119
west: 598614
east: 651978
nsres: 3
ewres: 3
rows: 29960
cols: 17788
cells: 532928480
I'm trying to run with the resolution of 3m, but when I change it to 30m,
there isn't a problem. Using much smaller regions doesn't seem to have
this problem. So is the file just too large at too small of a resolution?
I'll try to run Spearfish and let you know.
thanks again,
paul
> Paul Haverkamp wrote:
> > i'm a very new user to grass and am using r.cost in grass6.2. i'm
> > trying to run a cost analysis on my raster and having some difficulty.
> which version of 6.2? 6.2.0 or 6.2.1?
> how big is your region? (g.region -p) Does it happen if you make the
> region smaller or adjust the resolution?
> can you reproduce it using the Spearfish demo dataset? if so, can you
> post instructions with that in the grass bug tracker?
> thanks,
> Hamish
grassuser mailing list
http://grass.itc.it/mailman/listinfo/grassuser
