[GRASS-user] problems with r.cost
Jonathan Greenberg
greenberg at ucdavis.edu
Thu May 24 13:14:36 EDT 2007
Hamish (and all): Paul is working with me on this project, and the system we
are running it on is a 64-bit debian system with plenty of RAM/scratch space
(and the version we are using is the 64-bit grass release) -- why would
memory problems be an issue? We tried lowering the % memory but it doesn't
seem to help...
--j
-----Original Message-----
From: grassuser-bounces at grass.itc.it [mailto:grassuser-bounces at grass.itc.it]
On Behalf Of Hamish
Sent: Wednesday, May 23, 2007 6:51 PM
To: Paul Haverkamp
Cc: grassuser at grass.itc.it
Subject: Re: [GRASS-user] problems with r.cost
Paul Haverkamp wrote:
> > > i'm a very new user to grass and am using r.cost in grass6.2. i'm
> > > trying to run a cost analysis on my raster and having some
> > > difficulty.
> I am using 6.2.1, and g.region -p gives the info:
> north: 4269999
> south: 4180119
> west: 598614
> east: 651978
> nsres: 3
> ewres: 3
> rows: 29960
> cols: 17788
> cells: 532928480
> I'm trying to run with the resolution of 3m, but when I change it to
> 30m, there isn't a problem. Using much smaller regions doesn't seem
> to have this problem. So is the file just too large at too small of a
> resolution?
Your region is way too large for r.cost. It should exit with a memory
error, apparently it isn't doing that. (beyond "segment_seek: invalid
argument")
In r.cost try setting percent_memory=10 or so, but it will still take a
long long long time. Try running at 30m resolution to start with.
532928480 cells (533m) would need at least 2gig RAM to run at percent=100.
watch the progress with "top" from the command line. "M" will sort by
memory use, which is a bit more stable way of watching it.
Hamish
grassuser mailing list
http://grass.itc.it/mailman/listinfo/grassuser
