[GRASS-user] v.in.ascii don't work
Manuel Francisco Maestre Páez mfmap at tragsatec.es
Tue May 29 05:56:37 EDT 2007
Maybe a problem with gdal libraries. Has v.in.ascii worked some time? or
never worked?
-----grassuser-bounces at grass.itc.it escribió: -----
Para: gary <lists at lazygranch.com>
De: Poizot Emmanuel <poizot at cnam.fr>
Enviado por: grassuser-bounces at grass.itc.it
Fecha: 29/05/2007 11:07
cc: grassuser at grass.itc.it
Asunto: Re: [GRASS-user] v.in.ascii don't work
gary a écrit :
> When I had a similar problem, I ended up using csv file from a
> spreadsheet as the input file.
> Otto Dassau wrote:
>> Hi,
>> for me (GRASS 6.3cvs) the import of your test data works, the syntax is
>> correct. Maybe you need to check your test.txt for <space> values in
>> your
>> columns etc?
>> regards,
>>  Otto
>> On Tue, 29 May 2007 09:31:38 +0200
>> Poizot Emmanuel <poizot at cnam.fr> wrote:
>>> Hi all,
>>> I'm unable to input  text file in GRASS using v.in.ascii.
>>> I'm (trying) working on GRASS 6.2.1 under Ubuntu Fiesty
>>> I have a text file (test.txt) which containing:
>>> 1|3.5|43.6|2.3
>>> 2|3.55|43.605|1.2
>>> 3|3.51|43.621|-2.3
>>> 4|3.485|43.704|56.1
>>> 5|3.498|43.5|7.1058
>>> I would like to import it in a new layer with the following command:
>>> cat test.txt | v.in.ascii  out=test columns='nul int, x double, y
>>> double, val double' fs="|" x=2 y=3 z=0
>>> and the outputs of that command is:
>>> Maximum input row length: 20
>>> Maximum number of columns: 4
>>> Minimum number of columns: 4
>>> column: 1  type: integer
>>> column: 2  type: double
>>> column: 3  type: double
>>> column: 4  type: double
>>> Building topology ...
>>> 0 primitives registered     0 areas built     0 isles built
>>> Attaching islands:
>>> Attaching centroids: Topology was built.
>>> Number of nodes     :   0
>>> Number of primitives:   0
>>> Number of points    :   0
>>> Number of lines     :   0
>>> Number of boundaries:   0
>>> Number of centroids :   0
>>> Number of areas     :   0
>>> Number of isles     :   0
>>> So no points are imported in the layer.
>>> I turn around that problem wich normally should work, as what I raed
>>> everywhere, but not for me !!
>>> Regards
>>> E. POIZOT
> grassuser mailing list
> http://grass.itc.it/mailman/listinfo/grassuser
I check for spaces on columns, misllaneous character, etc. The text file
is clean.
I also check the bounadries of my region settings and it's ok, the
points are inside it.
I just produced a CSV file from a spreadsheet, and still not work.
How to know what happend durin v.in.ascii execution (debug or a log file) ?
Regards
EP
Cordialement
Emmanuel Poizot
Cnam/Intechmer
B.P. 324
50103 Cherbourg Cedex
Phone (Direct) : (00 33)(0)233887342
Fax : (00 33)(0)233887339
(See attached file: poizot.vcf)
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20070529/286f7ff4/poizot.obj
