[GRASS-user] Spatial Dissolve
Darren Cope darrencope at gmail.com
Wed May 30 09:17:42 EDT 2007
On 5/29/07, Leonardo Lami <lami at faunalia.it> wrote:
> > - run v.clean as per CORINE example (v.clean input=wateroriginal
> > output=waterclean tool=rmdupl) in GRASS shell
> > - at this point I noticed that the attribute values are not carried
> > through and I'm left with only "id" and "cat" - why is this, and will
> > it cause problems later on?
> See the output message of v.in.ogr, maybe there is some problems in the
> structure of the input table
Hi Leonardo:
Thanks for the idea.  I had originally thought that the v.in.ogr was
fine, and that the attributes were lost in the v.clean step.  However,
I looked again, and it does appear that only a portion of the
attributes (e.g. the first 137 features) came through during the
v.in.ogr step.  That may potentially be the cause of the problems with
v.clean?  I've attached the output of v.in.ogr, although I don't see
anything that indicated a problem?
---start output of v.in.ogr: ---
v.in.ogr 'dsn=C:/documents and
settings/dcope/desktop/shp/obm_OBMUSER_waterseg_polyne_poly.shp'
output=test -o
A datum name nad83 (North_American_Datum_1983) was specified without
transformation parameters.
Non-interactive mode: the GRASS default for nad83 is
towgs84=0.000,0.000,0.000.
Over-riding projection check.
Proceeding with import...
Layer: obm_OBMUSER_waterseg_polyne_poly
Importing map 1277 features...
Building topology ...
Registering lines:    1000
1837 primitives registered
Building areas:
1530 areas built
1496 isles built
Attaching islands:
Attaching centroids:
Topology was built.
Number of nodes     :   1663
Number of primitives:   1837
Number of points    :   0
Number of lines     :   0
Number of boundaries:   1837
Number of centroids :   0
Number of areas     :   1530
Number of isles     :   1496
Number of incorrect boundaries   :   341
Number of areas without centroid :   1530
Cleaning polygons, result is not guaranteed!
Topology was built.
Number of lines     :   0
Number of areas     :   -
Number of isles     :   -
Break polygons:
Registering points ... 128830
All points (vertices): 144066
Registered points (unique coordinates): 128830
Points marked for break:  1947
Breaks:     0
Breaks:    13
Breaks:    22
Breaks:    38
Breaks:    41
Breaks:    68
<snip>
Breaks:  1279
Remove duplicates:
Duplicates:     0
<snip>
Duplicates:   459
Break boundaries:
Intersections:     0
Intersections:     0 (line 637)
Intersections:     0 (line 1243)
Intersections:     0 (line 1875)
Intersections:     0 (line 2119)
Intersections:     0 (line 2398)
Intersections:     0 (line 2623)
Intersections:     0 (line 2859)
Intersections:     0
Remove duplicates:
Duplicates:     0
Clean boundaries at nodes:
Modifications:     0
<snip>
Modifications:     0
Change dangles to lines:
Removed dangles:     0  removed lines:     0
Remove bridges:
Removed bridges:     0  removed lines:     0
<snip>
Building areas:
1712 areas built
1421 isles built
Attaching islands:
Topology was built.
Number of nodes     :   1947
Number of primitives:   3116
Number of lines     :   0
Number of boundaries:   3116
Number of areas     :   1712
Number of isles     :   1421
Number of areas without centroid :   1712
Registering lines:    1000   2000   3000
3524 primitives registered
Building areas:
1712 areas built
1421 isles built
Attaching islands:
Topology was built.
Number of nodes     :   3233
Number of primitives:   3524
Number of lines     :   0
Number of boundaries:   2238
Number of centroids :   1286
Number of areas without centroid :   426
4 areas represent more (overlapping) features, because polygons
overlap in input layer(s). Such areas are linked to more than 1 row in
attribute table. The number of features for those areas is stored as
category in layer 2
1286 input polygons
total area: 1.945637e+008 (1712 areas)
overlapping area: 1.987796e+006 (4 areas)
area without category: 4.105847e+006 (426 areas)
Successfully finished
---end output of v.in.ogr: ---
