[GRASS-user] Rsun problems
Silvia Franceschi
silvia.franceschi at ing.unitn.it
Thu May 31 04:18:42 EDT 2007
Thanks Hamish,
very king.
Silvia
PS: how do you use r.series? I thought to use r.mapcalc
Hamish wrote:
> Silvia Franceschi wrote:
>> I am trying to use r.sun and have some problems understanding the
>> results. If I want the total irradiation in a specified day then I
>> have to select the option 2. In this case I obtain the following
>> maps: - beam_rad: irradiation raster file
>> - insol_time: insolation raster map
>> - diff_rad: irradiation raster map
>> - refl_rad: irradiation raster map
>> So I don't understand a few things... :-(
>> - where does GRASS save the irradiation raster file?
> it's not one output file, it's a raster map named whatever you gave the
> beam_rad option. see below.
>> - what is the difference between the diff_rad irradiation raster map
>> and the refl_rad irradiation raster map.
> one is diffuse light (think cloud scatter), the other reflected light
> (glare bouncing off ground hitting hillside??).
>> - I noticed that I have a raster map created with the name of the
>> beam_rad "file", so I think in this case GRASS makes a raster and not
>> a file, but what do these values means?
> yes, beam_rad mades a raster map, not some data file. This is already
> changed in the development source code.
> mode 2 units are Wh.m-2.day-1. Watt-hours per meter^2 per day.
>> - which of these maps created whit the command gives to me the total
>> radiation for the day? maybe I have to sum some of them but I don't
>> understand which of them to take into account.
> total = beam + diffuse + reflected
> (add with r.series)
> Hamish
