No subject
    Wed Nov 14 14:03:15 EST 2007
babbler{joe}180: gmake4.1
  SRC     = /usr/local/src/grass4.1.5/src
  CMD     = /usr/local/src/grass4.1.5/src/CMD
  HEADER  = sparc5
  ARCH    = 5.4
  GISBASE = /usr/local/grass4.1.5
  VERSION = 4.1 Spring 1993 Update Package 5, January 1995
/usr/local/src/gnuplot/gnuplot
  make -f OBJ.5.4/make.rules
gcc -g -o /usr/local/grass4.1.5/etc/bin/main/cmd/g.gnuplot OBJ.5.4/binary.o OBJ
.5.4/bitmap.o OBJ.5.4/command.o OBJ.5.4/contour.o OBJ.5.4/eval.o OBJ.5.4/gnubin
.o OBJ.5.4/graph3d.o OBJ.5.4/graphics.o OBJ.5.4/help.o OBJ.5.4/internal.o OBJ.5
.4/misc.o OBJ.5.4/parse.o OBJ.5.4/plot.o OBJ.5.4/readline.o OBJ.5.4/scanner.o O
BJ.5.4/setshow.o OBJ.5.4/specfun.o OBJ.5.4/standard.o OBJ.5.4/term.o OBJ.5.4/ut
il.o OBJ.5.4/version.o  /usr/local/src/grass4.1.5/src/libes/LIB.5.4/libdisplay.
a /usr/local/src/grass4.1.5/src/libes
/LIB.5.4/libraster.a /usr/local/src/grass4.1.5/src/libes/LIB.5.4/libgis.a -lter
mlib -lm
Undefined                       first referenced
 symbol                             in file
bzero                               OBJ.5.4/bitmap.o
bcopy                               OBJ.5.4/parse.o
getwd                               OBJ.5.4/command.o
ld: fatal: Symbol referencing errors. No output written to /usr/local/grass4.1.
5
make: *** [/usr/local/grass4.1.5/etc/bin/main/cmd/g.gnuplot] Error 1
This is the same header file I used to compile GRASS4.1.5 .The machine is
a SPARC 5 running SOLARIS 2.4.
The only thing that has change since the compilation of GRASS is
that I upgraded the gcc compiler from 2.5.6 to 2.7.2. This should
have no effect- should it!
I then applied the patche file enhpost.patches
and run gmake4.1 again. I got the same errors.
I would be gratefull for any HELP
joe
Joe.Leone at per.dwe.csiro.au
