[GRASS-user] Re: Call for documentation help
Patton, Eric epatton at nrcan.gc.ca
Wed Nov 7 15:37:15 EST 2007
WRT documentation standards, I ran a few small scripts on the source directory tree for the display, general, raster, and vector commands to see how much variation there is in the use of different headings and sections within the description.html pages.
I've attached the listing for the raster commands; as you can see, there's a fair bit of variation in the wording of sections in the html pages. If the goal is to use a uniform documentation style, we should probably figure out which headings are going to be accepted. I know it's not the most pressing issue, but a common style could save a lot of work in re-writes in the future.
OTOH, it may be deemed more important to allow flexibility in the use of headings for each module's html page.
Ideas?
~ Eric.
r.average
<H2>DESCRIPTION</H2>
<H2>EXAMPLE</H2>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.basins.fill
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHORS</H2>
r.bilinear
<H3>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.bitpattern
<H2>EXAMPLE</H2>
<H2>SEE ALSO</H2>
<H2>AUTHORS</H2>
r.buffer
<H2>NOTES</H2>
<H2>EXAMPLE</H2>
<H2>SEE ALSO</H2>
<H2>AUTHORS</H2>
r.carve
<H2>NOTES</H2>
<H2>EXAMPLE</H2>
<H2>BUGS AND CAVEAT</H2>
<H2>SEE ALSO</H2>
<H2>REFERENCES</H2>
<H2>AUTHOR</H2>
r.cats
<H2>NOTES</H2>
<H3>Input from a file</H3>
<H3>Default and dynamic category labels</H3>
<H2>EXAMPLES</H2>
<H2>TODO</H2>
<H2>SEE ALSO</H2>
<H2>AUTHORS</H2>
r.circle
<H2>EXAMPLES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.clump
<H2>ALGORITHM</H2>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.coin
<h2>NAME</h2>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHORS</H2>
r.colors
<h2>DESCRIPTION</h2>
<h2>EXAMPLES</h2>
<h2>SEE ALSO</h2>
<h2>AUTHORS</h2>
r.composite
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.compress
<H2>PROGRAM OPTIONS</H2>
<H2>FORMATS</H2>
<H3>PRE-3.0 FORMAT:</H3>
<H3>POST-3.0 FORMAT:</H3>
<H2>SEE ALSO</H2>
<H2>AUTHORS</H2>
r.contour
<H2>
<H2>
r.cost
<H2>OPTIONS</H2>
<H2>NULL CELLS</H2>
<H2>NOTES</H2>
<H4>Algorithm notes</H4>
<H2>EXAMPLES</H2>
<H4>Output analysis</H4>
<H4>Shortest distance surfaces</H4>
<H2>BUGS</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.covar
<H2>PRINCIPLE COMPONENTS</H2>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.cross
<H2>OPTIONS</H2>
<H2>EXAMPLE</H2>
<H2>SUPPORT FILES</H2>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.describe
<H3>PROGRAM USE</H3>
<H3>NON-INTERACTIVE PROGRAM USE</H3>
<h3>FLAGS</h3>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.digit
<H3>THE PROCESS:</H3>
<h4>Start a monitor and display a raster to help setup and zoom to area of interest</h4>
<h4>Digitizing an area based on a existing map; creating a new raster map</h4>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.distance
<H3>Explanation:</H3>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.drain
<H2>EXAMPLES</H2>
<H2>BUGS</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.fill.dir
<H2>EXAMPLE</H2>
<H2>ATTENTION</H2>
<H2>NOTE</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.flow
<H2>NOTES</H2>
<H2>Algorithm background</H2>
<H2>FURTHER NOTES</H2>
<H2>DIAGNOSTICS</H2>
<H2>SEE ALSO</H2>
<H2>AUTHORS</H2>
<H2>REFERENCES</H2>
r.grow2
<H2>SEE ALSO</H2>
<H2>AUTHORS</H2>
r.gwflow
<H2>NOTES</H2>
<H2>EXAMPLE</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.his
<H2>THE PROCESS</H2>
<H2>NOTES</H2>
<H2>EXAMPLE</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.in.arc
<h2>NOTES</h2>
<h2>SEE ALSO</h2>
<h2>AUTHOR</h2>
r.in.ascii
<H2>EXAMPLE</H2>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.in.bin
<H2>NOTES</H2>
<H2>EXAMPLES</H2>
<h3>GTOPO30 DEM</h3>
<h3>GMT</h3>
<h3>AVHRR</h3>
<h3>ETOPO2</h3>
<h3>TOPEX/SRTM30 PLUS</h3>
<H2>SEE ALSO</H2>
<H2>AUTHORS</H2>
r.info
<H2>ACCURACY</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.in.gdal
<!--<H2>OPTIONS</H2>
<H3>Flags:</H3>
<H2>GDAL supported raster formats</H2>
<H2>Location Creation</H2>
<H2>NOTES</H2>
<H2>EXAMPLES</H2>
<h3>GLOBE DEM</h3>
<h3>Worldclim.org</h3>
<h3>HDF</h3>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>REFERENCES</H2>
<H2>AUTHOR</H2>
r.in.gridatb
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.in.mat
<H2>NOTES</H2>
<H2>EXAMPLES</H2>
<H2>TODO</H2>
<H2>BUGS</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.in.poly
<H2>NOTES</H2>
<H2>INPUT FORMAT</H2>
<H2>EXAMPLE</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.in.xyz
<H2>NOTES</H2>
<h4>Memory use</h4>
<h4>Setting region bounds and resolution</h4>
<h4>Filtering</h4>
<h4>Reprojection</h4>
<h4>Interpolation into a DEM</h4>
<H2>EXAMPLE</H2>
<H2>TODO</H2>
<H2>BUGS</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.kappa
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.lake
<h2>KNOWN BUGS AND LIMITATIONS</h2>
<h2>MAPCALC EQUIVALENT - FOR GRASS HACKERS</h2>
<h2>SEE ALSO</h2>
<h2>AUTHOR</h2>
r.le
r.le.patch
<H2>NOTES</H2>
<H2>REFERENCES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.le.pixel
<H2>NOTES</H2>
<H2>REFERENCES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.le.setup
<H2>NOTES</H2>
<H2>REFERENCES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.le.trace
<H2>NOTES</H2>
<H2>REFERENCES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.li
<h2>NAME</h2>
<h2>KEYWORDS</h2>
<H2>NOTE</H2>
<H2>EXAMPLE</H2>
<H2>SEE ALSO</H2>
<H2>ADDING NEW INDICES</H2>
<H2>REFERENCES</H2>
<H2>AUTHORS</H2>
<HR>
r.los
<H2>NOTES</H2>
<H2>EXAMPLE</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.mapcalc
<H2>NAME</H2>
<H2>PROGRAM USE</H2>
<H2>OPERATORS AND ORDER OF PRECEDENCE</H2>
<H2>RASTER MAP LAYER NAMES</H2>
<H2>THE NEIGHBORHOOD MODIFIER</H2>
<H2>RASTER MAP LAYER VALUES FROM THE CATEGORY FILE</H2>
<H2>GREY SCALE EQUIVALENTS AND COLOR SEPARATES</H2>
<H2>FUNCTIONS</H2>
<H2>FLOATING POINT VALUES IN THE EXPRESSION</H2>
<H2>NULL support</H2>
<H2>EXAMPLES</H2>
<H2>NOTES</H2>
<H2>BUGS</H2>
<H2>SEE ALSO</H2>
<H2>AUTHORS</H2>
r.median
<H2>NOTES</H2>
<H2>EXAMPLE</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.mfilter.fp
<H2>FILTERS</H2>
<H2>EXAMPLE FILTER FILE</H2>
<H2>HOW THE FILTER WORKS</H2>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.mfilter
<H2>FILTERS</H2>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.mode
<H2>NOTES</H2>
<H2>EXAMPLE</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.neighbors
<H2>OPTIONS</H2>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.null
<h2>EXAMPLES</h2>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.out.arc
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.out.ascii
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.out.bin
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.out.gdal
<H2>SUPPORTED RASTER FORMATS</H2>
<H2>NOTES</H2>
<H2>EXAMPLES</H2>
<h4>Export the integer raster roads map to GeoTIFF format:</h4>
<h4>Export a DCELL raster map in GeoTIFF format suitable for ESRI software:</h4>
<h4>Export the floating point raster elevation map to ERDAS/IMG format:</h4>
<H2>GDAL RELATED ERROR MESSAGES</H2>
<H2>SEE ALSO</H2>
<H2>REFERENCES</H2>
<H2>AUTHOR</H2>
r.out.gridatb
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.out.mat
<H2>NOTES</H2>
<H2>EXAMPLE</H2>
<H2>TODO</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.out.mpeg
<h2>Example:</h2>
<H2>BUGS</H2>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.out.pov
<H2>EXAMPLE</H2>
<H2>AUTHOR</H2>
r.out.ppm3
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.out.ppm
<H2>NOTES</H2>
<H2>HINTS</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.out.tiff
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.out.vrml
<H2>WARNING</H2>
<H2>NOTE</H2>
<H2>BUGS:</H2>
<H2>TODO</H2>
<H2>AUTHOR</H2>
r.out.vtk
<H2>NOTES</H2>
<H3>Difference between point- and celldata</H3>
<H2>EXAMPLE</H2>
<H3>Simple Spearfish example</H3>
<H3>Spearfish example with RGB data</H3>
<H2>SEE ALSO</H2>
<H2>AUTHORS</H2>
r.param.scale
<h2>NOTES</h2>
<h2>Still to do</h2>
<h2>EXAMPLE</h2>
<h2>SEE ALSO</h2>
<h2>REFERENCE</h2>
<h2>AUTHOR</h2>
r.patch
<H2>EXAMPLE</H2>
<H2>NOTES</H2>
<H2>EXAMPLE</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.profile
<H2>OUTPUT FORMAT</H2>
<H2>EXAMPLES</H2>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.proj
<H4>Introduction</H4>
<H5>Map projections</H5>
<H5>Projecting vector maps within the GRASS GIS</H5>
<H4>Design of r.proj</H4>
<h2>NOTES</h2>
<h2>REFERENCES</h2>
<H2>SEE ALSO</H2>
<H2>AUTHORS</H2>
r.proj.seg
<h2>NOTES</h2>
<h2>REFERENCES</h2>
<H2>SEE ALSO</H2>
<H2>AUTHORS</H2>
r.quant
<H2> Quant rules </H2>
<H2>NOTE</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.random.cells
<H2>PARAMETERS</H2>
<H2>NOTES</H2>
<h2>REFERENCES</h2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.random
<H2>OPTIONS</H2>
<H3>Flags:</H3>
<H3>Parameters:</H3>
<H2>NOTES</H2>
<H2>EXAMPLES</H2>
<H2>BUGS</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.random.surface
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<h2>REFERENCES</h2>
<H2>AUTHORS</H2>
r.reclass
<H2>INTERACTIVE PROGRAM USE: EXAMPLE</H2>
<H2>NON-INTERACTIVE PROGRAM USE: RECLASS RULES</H2>
<H2>NON-INTERACTIVE PROGRAM USE: EXAMPLES</H2>
<H2>NOTES</H2>
<H2>BEWARE</H2>
<H2>SEE ALSO</H2>
<H2>AUTHORS</H2>
r.recode
<h2>EXAMPLES</H2>
<H2>AUTHOR</H2>
r.region
<H2>NOTE</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.report
<H2>EXAMPLE:</H2>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.resamp.interp
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.resample
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.resamp.rst
<h2>NOTES</h2>
<h2>SEE ALSO</h2>
<h2>AUTHORS</h2>
<h2>REFERENCES</h2>
r.resamp.stats
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.rescale.eq
<H2>EXAMPLE</H2>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.rescale
<H2>EXAMPLE</H2>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.series
<H2>NOTES</H2>
<H2>EXAMPLE</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.slope.aspect
<h2>NOTES</h2>
<h2>REFERENCE</h2>
<h2>SEE ALSO</h2>
<h2>AUTHORS</h2>
r.statistics
<H2>EXAMPLES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.stats
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.sum
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.sun
<h2> OPTIONS</h2>
<h2>
<h3>Shadow maps</h3>
<H2>EXAMPLE</H2>
<h2>SEE ALSO</h2>
<h2>REFERENCES</h2>
<h2>AUTHORS</h2>
r.sunmask
<h2>Notes</h2>
<h2>Acknowledgements</h2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.support
r.support_headers_listing.txt
r.support.stats
<h2>NOTES</h2>
<h2>SEE ALSO</h2>
<h2>AUTHORS</h2>
r.surf.area
<H2>NOTE</H2>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.surf.contour
<H2>NOTES</H2>
<H2>BUGS</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.surf.fractal
<H2>NOTE</H2>
<H2>REFERENCE</h2>
<H2>SEE ALSO</H2>
r.surf.gauss
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.surf.idw2
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.surf.idw
<A NAME="notes.html"><H2>NOTES</H2></A>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.surf.random
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.terraflow
<H2>NAME</H2> <B><I>r.terraflow </I></B>- computation of <i>flow
<H2>SYNOPSIS</H2>
<H2>OPTIONS</H2>
<H3>Flags:</H3>
<H3>Examples</H3>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHORS</H2>
<H2>REFERENCES</H2>
r.texture
<h2>NOTES</h2>
<h2>BUGS</h2>
<h2>REFERENCES</h2>
<h2>SEE ALSO</h2>
<h2>AUTHOR</h2>
r.thin
<H2>NOTE</H2>
<H2>NOTE</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.timestamp
<H2>NOTES</H2>
<H2>EXAMPLES</H2>
<H2>TIMESTAMP FORMAT</H2>
<h2>SEE ALSO</h2>
<H2>BUGS</H2>
<H2>AUTHOR</H2>
r.topidx
<H2>SEE ALSO</H2>
<h2>REFERENCE</h2>
<H2>AUTHORS</H2>
r.topmodel
<H3>Selected Parameters:</H3>
<H2>SEE ALSO</H2>
<H2>AUTHORS</H2>
r.to.rast3elev
<H2>NOTES</H2>
<h2>Example</h2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.to.rast3
<H2>NOTES</H2>
<h2>EXAMPLES</h2>
<h3>EXAMPLE 1</h3>
<h3>EXAMPLE 2</h3>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.to.vect
<H3>Points</H3>
<H3>Lines</H3>
<H3>Areas</H3>
<H2>BUGS</H2>
<H2>AUTHOR</H2>
r.transect
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.univar2
r.univar_headers_listing.txt
r.volume
<H2>NOTES</H2>
<H2>EXAMPLE OF REPORT</H2>
<h3>CENTROIDS</h3>
<h3>FORMAT OF CENTROIDS table<BR></h3>
<h3>APPLICATIONS</h3>
<H2>AUTHOR</H2>
r.walk
<H2>SEE ALSO</H2>
<H2>REFERENCES</H2>
<H2>AUTHORS</H2>
r.water.outlet
<H3>Selected Parameters</H3>
<H2>NOTES</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.watershed
r.watershed_headers_listing.txt
r.what.color
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
r.what
<H2>EXAMPLES</H2>
<h4>Input from <tt>stdin</tt> on the command line</h4>
<h4>Input from a text file containing coordinates</h4>
<h4>Input coordinates given as a module option</h4>
<h4>Input coordinates piped from another program</h4>
<h4>Output containing raster map category labels</h4>
<H2>NOTE</H2>
<H2>SEE ALSO</H2>
<H2>AUTHOR</H2>
