[GRASS-user] help needed with creation of (printable) maps
WolfgangZ wollez at gmx.net
Thu Nov 8 10:24:50 EST 2007
Hi all,
this is slightly off topic, but at least Grass should be used to create
the base data for maps.
We want to create a map of a part of a mountain. It will consist of
several layers (DOP, height lines, polygon lines, coordinate grid, ...).
I've never done something like this and I hope that I can get some
reccomendations regarding the work flow and suitable software to use.
One big problem is that one of my friends prefers to use Adobe
Illustrator to create one of these layers, but as far as I know
Illustrator can't handle anything else as paper units and therefore all
georeferenciation is lost. The advantage of Illustrator would be that it
is easy to colorize (or fill) areas and create nice looking plots.
An other task is to create (a kind of) atlas where parts of the big map
fits on single A4 sheets. Are there any possibilities to cut out parts
of a big map and automatically create a grid (with numbers at the border)?
I had a short look at gmt, but I find it quite cryptic to use.
Any suggestions are welcome.
Regards
Wolfgang
