[GRASS-user] Network Topology Reconstruction
Markus Neteler
neteler at fbk.eu
Thu Nov 8 19:12:41 EST 2007
v.edit in latest GRASS 6.3 is also a good candidate.
Markus
On Thu, Nov 08, 2007 at 07:38:16PM +0100, M S wrote:
> v.clean has various parameters. Did you try increasing the threshold
> for the snapping? I'd try in relatively small increments and observe
> the results, because having a snapping threshold too high will
> collapse features you dont want collapsed.
> Mark
> On 11/8/07, Andre Hauptfleisch <ahaupt at gmail.com> wrote:
> > Good day,
> > I'm busy working on road extraction from QuickBird imagery. I've managed to
> > get my centrelines into a network of vectors (thanks to Grass!), but I would
> > like to run a topology reconstruction tool of sorts.
> > I've tried the v.clean component, but had little effect. I suppose my
> > branches and gaps are to big for them to be pruned and connected.
> > Does anyone know of a component, or external tool that could complete my
> > vector network?
> > I've various papers on the topic, but unfortunately I don't have enough time
> > implement and experiment with these at this stage.
> > Any hints? Ideas?
> > Regards,
> > Andre
> > grassuser mailing list
> > grassuser at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grassuser
Markus Neteler <neteler fbk eu> http://mpa.fbk.eu/markus/
FBK-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
