[GRASS-user] Loop - How To? R.sun manual?
    Dylan Beaudette
    dylan.beaudette at gmail.com
    Mon Nov 12 13:53:27 EST 2007
Hi Jerry,
Which FAQ would that be... Perhaps a patch to the documentation would be in
order. I will see what I can do in the next couple of days. Or- if you would
like work up the patch and send it to one of the developers like Markus.
Cheers,
Dylan
On Monday 12 November 2007 10:38:49 am Jerry Nelson wrote:
> Dylan, Could you stick that in the faq? I might find that very useful some
> day and it would be better for me not to clutter up my local directory?
> Thanks, Jerry
> -----Original Message-----
> From: grassuser-bounces at grass.itc.it
> [mailto:grassuser-bounces at grass.itc.it] On Behalf Of Dylan Beaudette
> Sent: Monday, November 12, 2007 12:19 PM
> To: grassuser at grass.itc.it
> Subject: Re: [GRASS-user] Loop - How To? R.sun manual?
> On Monday 12 November 2007 10:08:40 am RolandPape wrote:
> > Hallo,
> > I am a quite novice user of GRASS and therefore my question might be
> rather
> > simple: I would like to calculate global radiation for each day of the
> year
> > by using r.sun. Instead of doing so day by day I thought about using a
> > script defining a  loop - but as common Windows user I am not familiar
> with
> > writing Unix-shell scripts. I appreciate any suggestions!
> > In one post Dylan and Hamish discussed about a r.sun manual - is it
> already
> > available? I did not found it except the one at
> > http://grass.itc.it/grass62/manuals/html62_user/r.sun.html
> > Many thanks!
> > Kind regards,
> > Roland Pape
> > Department of Geography
> > University of Bonn
> Hi,
> Not sure how to do this on windows, but on a linux / unix machine the
> construct is like this:
> for x in `seq 1 365`
> do
> echo "Running r.sun for day $x: Linke turbidity factor= ${linke[$x]}"
> r.sun --q --o -s elevin=$elev aspin=$aspect slopein=$slope \
> diff_rad=diffuse_0$x beam_rad=beam_0$x insol_time=time_0$x \
> day=$x \
> lin=${linke[$x]}
> done  & # run in the background
> note that i am using a variable to store the map names:
> elev=elev_meters at solar
> aspect=aspect at solar
> slope=slope at solar
> also note that i am specifying a daily TL value, from an array like this:
> linke[1]=4.1175
> linke[2]=4.1108
> linke[3]=4.104
> linke[365]=4.2324
> specify a smaller range of days, and run multiple instances of the above to
> use multiple cores/ processors on such a machine. You may need to do some
> googling to convert the above for-loop construct into a windows-compatible
> version.
> cheers,
> Dylan
> grassuser mailing list
> http://grass.itc.it/mailman/listinfo/grassuser
