[GRASS-user] PostgreSQL connection just not working - v.in.ogr
and QuantumGIS
John Abraham
jabraham at ucalgary.ca
Sun Nov 11 17:32:27 EST 2007
Well I did manage to get something to work. I'm not sure if setting the
path to the Postgres libraries was important or not.
In QGIS I'm able to connect to the database in QGIS using
db.connect driver=pg database=postgis schema=public
and then I'm able to import a shapefile into the PostGIS database using
v.in.ogr dsn=C:\MontgomeryShapefiles\Autauga\BLDG_FOOTPRINT.shp
output=bldg_footprint2 -o
That put a table in the database from the shapefile. Not sure what to
do with it now, because I guess grass vector layers aren't PostGIS
tables, and when I try to add it as a GRASS vector layer QGIS crashes.
But it's movement foreward anyways.
Thanks for caring, I'll struggle some more and try to figure this thing
out. I think I have a paradigm problem in that I'm expecting everything
to be stored in a PostGIS database using PostgreSQL, but Grass seems to
be insisting on keeping things in its own dbf files instead.
John
Moritz Lennert wrote:
> John Abraham wrote:
>> I am having a heck of a time getting a connection to
>> PostGIS/PostgreSQL to work.
> I can't say anything about QGIS, but:
>> I also installed grass63RC1 standalone. I got it running, but can't
>> connect to my data. I've tried every connection string I can think
>> of, and I always get
>> Unable to open datasource.
> This could be because GRASS doesn't find the path to your postgres
> libraries.
> For the standalone wingrass binary, you can set the path in the
> grass63.bat file using something like this:
> set PATH=c:\PathToPostgres\lib;%PATH%
> Be sure to put the postgres path at the beginning, not after the
> %PATH% because this could cause a library conflict.
>> I went into the ControlPanel -> Administrative Tools -> Datasources
>> and defined an ODBC datasource that seems to connect to the database,
>> but I have no idea how to make Grass connect via a pre-defined ODBC
>> connection.
> ODBC is not compiled as a driver in the current version of the windows
> GRASS binaries. See
> http://geog-pc40.ulb.ac.be/grass/wingrass/winconfig.log for a list of
> what is and is not compiled.
> It will in a future version.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20071111/83f6db0d/attachment.html
