[GRASS-user] V.voronoi
Sampson, David dsampson at NRCan.gc.ca
Wed Nov 14 08:45:34 EST 2007
Hey folks,
Looking for a some ideas and help.
I am ttrying to use the v.voronoi (in wingrass) tool and it is
perplexing me with the results I am getting. Here is the scenario.
I am trying to anaylise the spatial distribution of road intersections.
I started with a road network file from Statistics Canada, and clipped
out the roads of the city of Ottawa for my subset. I created a new
vector containing only the nodes of the Ottawa network. The resulting
vector has the following basic stats
Type of Map:  vector (level: 2)
 |   Number of points:       48156           Number of areas:      0
 |   Number of lines:        0               Number of islands:    0
 |   Number of boundaries:   0               Number of faces:      0
 |   Number of centroids:    0               Number of kernels:    0
 |   Map is 3D:              0
 |   Number of dblinks:      2
The nodes represent both road terminations and intersections.
I am new to using Voronoi charts but when I run the v.voronoi script I
expect it to create a polygon for each node.
Instead when I run the basic stats on the new Veronoi vector I get:
 |   Number of points:       0               Number of areas:      1
 |   Number of lines:        0               Number of islands:    1
 |   Number of boundaries:   4               Number of faces:      0
 |   Map is 3D:              0
 |   Number of dblinks:      1
I get a rectangular shape that is located just north of ONE of the nodes
in the coverage. As I zoom out some other nodes apear surounding
rectangualr shape...  The manual doesn't shed light on my situation.
Any help, experieince or knowledge would be great.
Cheers
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20071114/1baa698c/attachment.html
