[GRASS-user] sum of areas of certain attributes
Moritz Lennert mlennert at club.worldonline.be
Thu Nov 15 06:12:51 EST 2007
[please always cc the list to let everyone profit of the discussion]
On 15/11/07 11:10, Dr. Manuel Seeger wrote:
> Thanks Moritz,
> but I think I did not explain clear enough.
> v.to.db calculates the values for each category (here this is each
> polygon), but I need the sum of values for different classes, which are
> composed by a changing number of polygons. I want to know the area of
> each class.
After running v.to.db, you can run a select on the classification
column. Something like:
echo "select sum(area) from TABLE group by ClassificationColumn" | db.select
If your classification information is in integer form, you can also use
v.reclass:
v.reclass in=OrigMap out=ReclassMap Column=ClassificationColumn
and then v.to.db on ReclassMap.
Moritz
> how?
> Thank you!
> Manuel
> Moritz Lennert schrieb:
>> On 15/11/07 08:27, Dr. Manuel Seeger wrote:
>>> Hello list,
>>> I have a polygon map with a huge table, in which some columns give
>>> the information about a classification of the single polygons (these
>>> are represnted by single categories). I would like to calculate e.g.
>>> the sum of areas belonging to each class. How can I do this
>>> I tried a way by extracting the class needed indiviadually,
>>> generating a new tabel and so on, but it seems to be quite
>>> complicated. Is there a more simple way to get the results?
>> v.to.db with option=area ?
>> Moritz
