[GRASS-user] Creating dem using a contour map.
Fri Nov 16 18:29:10 EST 2007
Bob Moskovitz wrote:
> I have a 20 foot contour map shapefile that has over 47000 line strings.
> Many of these lines have gaps (see
> http://picasaweb.google.com/bobdebm/Problems/photo#5133539789447176242 )
> in many of the contour lines.  I want to use v.surf.rst to make a dem.  Will
> I have problems using this file?
v.to.rast + r.surf.contour  is the usual way for creating DEMs from contour
lines.
r.surf.contour still needs some updating from the GRASS 4 days, ie the output
is integer only and it treats 0 elevation as NULL. you can work around that by
multiplying the input map by 1000 or 10000 and then shifting 0 values up one
unit before processing and dividing by the same after.
v.surf.rst has issues with contour line input, as it gives detail where many
input points exist. For a line this means lots of points clustered along the
line and the surface gets streched to that. You can generate a surface then
take a random sample (ie evenly distributed in space) from that then rerun
*.surf.* on the random map for something smoother. Or cull out many of the
points when you converting lines to points.
it's not really ideal...
Hamish
      ____________________________________________________________________________________
Get easy, one-click access to your favorites.
Make Yahoo! your homepage.
http://www.yahoo.com/r/hs
