[GRASS-user] MODIS HDF conversion in TIF tool.
Ivan Shmakov
ivan at theory.asu.ru
Fri Nov 16 23:22:32 EST 2007
>>>>> Hamish <hamish_nospam at yahoo.com> writes:
>>> Could the swath data be reprojected using gdalwarp's -tps thin
>>> plate spline function? ISTR that's what -tps was commisioned
>>> for. (??)
>> I've tried gdalinfo(1) on AIRS .hdf:
>> $ gdalinfo AIRS.2007.05.31.214.L2.RetStd.v4.0.9.102.D07281163221.hdf
>> and it shows no ground control points. I suppose, this is because
>> the GCP's are given in separate HDF arrays (Latitude & Longitude),
>> and not in the metadata. Solving this problem may make gdalwarp(1)
>> an alternative to HEG.
> you can use gdal_translate to add (per scanline) GCPs to the metadata
> before running gdalwarp. gdal_translate -gcp pixel line easting
> northing [elevation]
Looks sensible. Thanks!
>> The one more problem with the MODIS L2 data is that it consists of
>> overlapping scans -- MODIS could ``see'' some parts of the Earth in
>> consequent scans. Like this (intended to be viewed with a monospace
>> font):
> I think you may get a much better answer about this if you ask on the
> gdal-dev mailing list. (www.gdal.org) Lots of smart experts on this
> stuff there.
ACK.
Perhaps, breaking the input dataset into pieces corresponding to
the instrument scans (e. g., 10 rows per MODIS scan at 1 km
resolution), then warping them one by one will do the thing. I
have to check the GDAL API as well...
