[GRASS-user] r.patch for stitching rasters?
Sat Nov 17 17:17:47 EST 2007
Charles:
> > > I couldn't figure out how to make gdal_merge output NULLs
> > > instead of 0s (and what formats support NULLs?).
> > r.mapcalc can easily convert your 0s into NULLS with the expression:
> > newmap = if(map == 0, null(), map)
another way is:
 r.null map=yourmap setnull=0
> > r.mapcalc will solve most raster problems. GRASS users are advised to know
> > that program inside and out.
agreed.
Boris Avdeev wrote:
> Well, you assuming that NULL=0, but the sole reason for having NULL
> layer in grass is that those values are not identical.
true, the data is lost when NULL is mixed with 0 in the first place, not when
changing 0->NULL.
Hamish
      ____________________________________________________________________________________
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
