[GRASS-user] MODIS HDF conversion in TIF tool.
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Tue Nov 20 09:56:29 EST 2007
Hello Ivan!
You think your script would be applicable to Surface Reflectance
products (L2) ?
Sorry for bothering again, but since I've limited experience with
scripts... I ask before I I try to modify it for my need.
Ivan Shmakov wrote:
>>>>>> Hamish <hamish_nospam at yahoo.com> writes:
> >>>> Reprojecting and subsetting of HDF-EOS grid data is, indeed,
> >>>> straight-forward, and usually could be done with, e. g.,
> >>>> gdalwarp(1). Not so for the swath data.
> >>> Could the swath data be reprojected using gdalwarp's -tps thin
> >>> plate spline function? ISTR that's what -tps was commisioned
> >>> for. (??)
> >> I've tried gdalinfo(1) on AIRS .hdf:
> >> $ gdalinfo AIRS.2007.05.31.214.L2.RetStd.v4.0.9.102.D07281163221.hdf
> >> and it shows no ground control points. I suppose, this is because
> >> the GCP's are given in separate HDF arrays (Latitude & Longitude),
> >> and not in the metadata. Solving this problem may make gdalwarp(1)
> >> an alternative to HEG.
> > you can use gdal_translate to add (per scanline) GCPs to the metadata
> > before running gdalwarp. gdal_translate -gcp pixel line easting
> > northing [elevation]
> Indeed, it works, at least for the AIRS data. (Although I've
> had to upgrade GDAL 1.3.2, as supplied with Debian 4.0 r1, to
> 1.4.3.)
> For those who are interested, the script I've used looks roughly
> as follows:
> --cut--
> #!/bin/bash
> file=AIRS.2007.07.09.079.L2.RetStd.v4.0.9.102.D07190164053.hdf
> file_gcp=airs-2007-07-09-gran-79-l2-retstd-tsurfstd-gcp+0.5.tiff
> file_out=airs-2007-07-09-gran-79-l2-retstd-tsurfstd-gcp+0.5-laea-10km.tiff
> ## FIXME: specify ``no projection'' instead?
> source_srs='+proj=latlong'
> target_srs='+proj=laea +lat_0=55.0 +lon_0=90'
> ## FIXME: more clean error handling
> set -x -e
> long_lat_to_gcp () {
> gawk '$1 != -9999 && $2 != -9999 {
> print "-gcp", (NR - 1) % 30 + .5, int ((NR - 1) / 30) + .5,
> $1, $2;
> gdal_translate \
> $(paste <(hdfdump --text "$file" {Long,Lat}itude) | long_lat_to_gcp) \
> "HDF4_EOS:EOS_SWATH:\"$file\":L2_Standard_atmospheric&surface_product:TSurfStd"
> "$file_gcp"
> gdalwarp \
> -tps -s_srs "$source_srs" -t_srs "$target_srs" \
> -tr 1e4 1e4 \
> "$file_gcp" "$file_out"
> --cut--
> Is there any chance that GDAL will obtain ``GCPs'' from the
> HDF-EOS file directly?
> >> The one more problem with the MODIS L2 data is that it consists of
> >> overlapping scans -- MODIS could ``see'' some parts of the Earth in
> >> consequent scans.
> > I think you may get a much better answer about this if you ask on the
> > gdal-dev mailing list. (www.gdal.org) Lots of smart experts on this
> > stuff there.
> I'm cross-posting it there.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://www.nabble.com/MODIS-HDF-conversion-in-TIF-tool.-tf4799564.html#a13858358
Sent from the Grass - Users mailing list archive at Nabble.com.
