[GRASS-user] cvs - error Ubuntu 7.10
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Tue Nov 20 10:39:25 EST 2007
Hi Christine!
I really don't know how to help with this errors.
However,
a. Why don't sudo apt-get install grass (GRASS 6.2 is in the Gutsy
repositories)
or
b.Why don't you try to re-compile GRASS from source (?).
. Decide where you want to put your grass source code
e.g. /usr/local/src
Go there and create a directory (e.g. GRASS63)
* Give the appropriate rights... "sudo chown yourloginid:yourloginid
/usr/local/src/GRASS63" and "sudo chmod a+rx GRASS63/"
. Download the source code via cvs
[ You need cvs tool -- install with "sudo apt-get install cvs" ]
* Before trying to compile the source code, check the pre-requisities &
configure. There is a script (written for Ubuntu 6.06 -- link is below ) in
which all necessary steps are described.
. Download and check it out "less makegrass.sh"
Hope this helps.
http://grass.gdf-hannover.de/wiki/Compile_and_Install#Ubuntu_6.06
Christine Sandmeier wrote:
> Hello
> I upgraded from Ubuntu 6.06 to 7.10 and since then I got
> child process exited abnormally
> Error in startup script: can't read "parts(w)": no such variable
> while executing
> "set $parts(w) [expr round($parts(w)/$parts(ewres))*$parts(ewres)]"
> (procedure "MapCanvas::zoom_gregion" line 16)
> invoked from within
> "MapCanvas::zoom_gregion $mon"
> (procedure "MapCanvas::create" line 40)
> invoked from within
> "MapCanvas::create"
> (procedure "Gm::startmon" line 11)
> invoked from within
> "Gm::startmon"
> (procedure "Gm::create" line 79)
> invoked from within
> "Gm::create"
> (procedure "main" line 30)
> invoked from within
> "main $argc $argv"
> (file "/usr/local/grass-6.3.cvs/etc/gm/gm.tcl" line 640)
> when I tried to enter location mapset.
> Then I updated my grass cvs and got following errors:
> Started compilation: Di 20. Nov 16:10:14 CET 2007
> Errors in:
> /home/chrischne/grass6/lib/form
> /home/chrischne/grass6/vector/v.digit
> root at Iggel:~/grass6# cd lib/form/
> root at Iggel:~/grass6/lib/form# make
> gcc -L/home/chrischne/grass6/dist.i686-pc-linux-gnu/lib
> -Wl,--export-dynamic
> -Wl,-rpath-link,/home/chrischne/grass6/dist.i686-pc-linux-gnu/lib -o
> /home/chrischne/grass6/dist.i686-pc-linux-gnu/etc/form/form
> OBJ.i686-pc-linux-gnu/form.o -lgrass_dbmiclient -lgrass_dbmibase
> -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz
> -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis
> -lgrass_datetime -lz -lgrass_datetime \
> -ltk8.4 -lm -ltcl8.4 -lm -lm -lz
> OBJ.i686-pc-linux-gnu/form.o: In function `main':
> /home/chrischne/grass6/lib/form/form.c:296: undefined reference to
> `Tk_Main'
> collect2: ld gab 1 als Ende-Status zurück
> make: *** [/home/chrischne/grass6/dist.i686-pc-linux-gnu/etc/form/form]
> Fehler 1
> How do I solve these problems to get grass running again?
> Thanks in advance
> Christine
> Psssst! Schon vom neuen GMX MultiMessenger gehört?
> Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://www.nabble.com/cvs---error-Ubuntu-7.10-tf4844145.html#a13859371
Sent from the Grass - Users mailing list archive at Nabble.com.
