[GRASS-user] HDF-EOS swath to grid (GeoTiff) conversion
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Wed Nov 21 08:42:23 EST 2007
I will have to study that (!) carefully. Thank you for your time.
BTW: I tried to reproject MODIS surface reflectance data with Markus script
first from sinusoidal to WGS84 and then to HGRS87. And it works... ! But I
can't get it in one line command successfuly.
I posted also in gdal (as I unterstand -with my limited experiences- it is a
gdal-issue).
Link to gdal-dev:
http://www.nabble.com/warping-MODIS-data-with-gdal-tf2688531.html
Ivan Shmakov wrote:
>>>>>> Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de> writes:
>  >>> you can use gdal_translate to add (per scanline) GCPs to the metadata
>  >>> before running gdalwarp.  gdal_translate -gcp pixel line easting
>  >>> northing [elevation]
>  >> Indeed, it works, at least for the AIRS data.  (Although I've
>  >> had to upgrade GDAL 1.3.2, as supplied with Debian 4.0 r1, to
>  >> 1.4.3.)
>  >> For those who are interested, the script I've used looks roughly
>  >> as follows:
>  > You think your script would be applicable to Surface Reflectance
>  > products (L2) ?
> 	Do you mean MODIS L2 data?  Well, I'll assume it for now...
>  > Sorry for bothering again, but since I've limited experience with
>  > scripts... I ask before I I try to modify it for my need.
> 	I'll try to comment on some of the points where the script is
> 	tied closely to the AIRS L2 data format.
>  >> --cut--
>  >> #!/bin/bash
>  >> file=AIRS.2007.07.09.079.L2.RetStd.v4.0.9.102.D07190164053.hdf
>  >> file_gcp=airs-2007-07-09-gran-79-l2-retstd-tsurfstd-gcp+0.5.tiff
> file_out=airs-2007-07-09-gran-79-l2-retstd-tsurfstd-gcp+0.5-laea-10km.tiff
>  >> ## FIXME: specify ``no projection'' instead?
>  >> source_srs='+proj=latlong'
> 	First of all, this seems to specify the projection system for
> 	the GCPs.  Thus, it's essential.  No FIXME: needed.
>  >> target_srs='+proj=laea +lat_0=55.0 +lon_0=90'
>  >> ## FIXME: more clean error handling
>  >> set -x -e
>  >> long_lat_to_gcp () {
>  >>     gawk '$1 != -9999 && $2 != -9999 {
>  >>               print "-gcp", (NR - 1) % 30 + .5, int ((NR - 1) / 30) +
> .5, $1, $2;
> 	Here, the `-gcp MINOR MAJOR LONGITUDE LATITUDE' lines are made.
> 	It's assumed that the data is stored as an 30x45 (30 pixels
> 	along the minor dimension) array, i. e.:
> a [1, 1] ... a [1, 30] a [2, 1] ... a [2, 30] ... a [45, 30]
> 	These are to be tailored for the data to be processed (e. g.,
> 	1354 x (10 * scans) for 1 km MODIS L2 swath.)
>  >> gdal_translate \
>  >>     $(paste <(hdfdump --text "$file" {Long,Lat}itude) |
> long_lat_to_gcp) \
> 	Extraction of the geolocation arrays is done with `hdfdump' [1],
> 	yet another ``HDF to plain-something'' conversion tool.  It
> 	could probably be done with `hdp' or GRASS (through the ``x, y''
> 	location) as well.
> 	Now, the `-gcp ...' lines are put into the command line for
> 	`gdal_translate'.  Command line arguments arrays are subject to
> 	OS- (and configuration-)dependent limits, and it's assumed that
> 	there's enough room for that many options.
> 	This assumption could easily become false for MODIS data on most
> 	OS, with some 1000000 points (or more.)  Either some points are
> 	to be discarded, or the GCP setting is to be applied in multiple
> 	passes.  I haven't tried doing either.
> "HDF4_EOS:EOS_SWATH:\"$file\":L2_Standard_atmospheric&surface_product:TSurfStd"
> 	This line have to be tailored according to the way GDAL ``sees''
> 	the file.  One could use `gdalinfo' on the file in question to
> 	find the pattern one needs.
>  >>     "$file_gcp"
>  >> gdalwarp \
>  >>     -tps -s_srs "$source_srs" -t_srs "$target_srs" \
>  >>     -tr 1e4 1e4 \
> 	Since MODIS data has finer resolution than AIRS, the destination
> 	resolution should be changed as well.  E. g., `-tr 1e3 1e3'
> 	could probably be used for 1 km MODIS L2 data.
>  >>     "$file_gcp" "$file_out"
>  >> --cut--
>  >> Is there any chance that GDAL will obtain ``GCPs'' from the
>  >> HDF-EOS file directly?
> 	Of course, this would eliminate all the aforementioned issues,
> 	and the script itself.
>  >>>> The one more problem with the MODIS L2 data is that it consists of
>  >>>> overlapping scans -- MODIS could ``see'' some parts of the Earth in
>  >>>> consequent scans.
> 	This is one more question I've had to check.  May be the
> 	conversion has to be done scan-wise -- each scan is to be
> 	selected and georeferenced (with `gdal_translate' and, e. g.,
> 	the above script), then reprojected with `gdalwarp'.  The
> 	resulting reprojected strips are to be somehow merged after.
> [1] http://theory.asu.ru/~ivan/devel/hdfdump/
> PS.  I feel that the gdal-dev mailing list is a better place to discuss
> 	this kind of problems.  Could we move there?
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://www.nabble.com/MODIS-HDF-conversion-in-TIF-tool.-tf4799564.html#a13877276
Sent from the Grass - Users mailing list archive at Nabble.com.
