[GRASS-user] Filling holes in polygons
Jarek Jasiewicz
jarekj at amu.edu.pl
Thu Nov 22 13:56:56 EST 2007
Hamish wrote:
> Jaros³aw Jasiewicz wrote:
>> The problem is simple:
>> If I want to remove small single areas I use v.to.db to upload areas to
>> database and next extract poligons with area grater than thereeshols
>> But how to perform opposite operation:
>> I have polygnos with some holes. I would like remove the smalllest (not
>> all)
> the task is to remove small holes, correct?
> the vector engine can certainly do it, but I don't know what module frontend to
> them could do it. some ideas:
> 'v.clean tool=rmarea' may help to remove small areas
> if you could give the holes centroids you could v.clean remove small areas +
> create a error= map, then use v.overlay to wipe out from the original?
> v.dissolve to get rid of left over boundaries (v.distance to set hole's cat
> from nearest area first?)
> The SQL approach is interesting.
> run v.buffer then see which features disappear?
> note GRASS sometimes calls holes in areas "islands".
> Hamish
> ____________________________________________________________________________________
> Be a better sports nut! Let your teams follow you
> with Yahoo Mobile. Try it now. http://mobile.yahoo.com/sports;_ylt=At9_qDKvtAbMuh1G1SQtBI7ntAcJ
well, it seems that for less than 50 v.digit apper the best solution
thanks for answer
Jarek
