[GRASS-user] Database login hassles
Richard Chirgwin rchirgwin at ozemail.com.au
Tue Nov 27 19:24:36 EST 2007
All,
One of my Grass users is running into a consistent problem with a Mysql
database login.
After running db.connect and db.login from a mapset, some maps (stored
in other mapsets) retain blank usernames. Opening the other mapsets and
running the db.connect / db.login does not fix the problem - in other
words, for some reason Grass is failing to store the new login details.
At the moment, I just want to know the file location for the login
details, so I can run a hard-code fix!
Richard Chirgwin
