[GRASS-user] grass 6.2.3 cannot find BLAS
Fri Nov 30 17:44:30 EST 2007
Hernán De Angelis wrote:
> Thanks for that!  Here are the last lines of config.log. Configure
> complains about undefined refernces to things. I guess it might be
> something related to gcc/gfortran but I can't understand the cause of
> the failure.
> configure:12134: checking whether to use BLAS
> configure:12156: checking for location of BLAS library
> configure:12183: checking for dnrm2_ in -lblas
> configure:12200: gcc -o conftest -g -O2     -Wl,--export-dynamic
> conftest.c -lblas -lm   1>&5
> /usr/lib/gcc/i586-suse-linux/4.1.2/../../../libblas.so: undefined
> reference to `_gfortran_st_write_done'
> reference to `_gfortran_transfer_integer'
> reference to `_gfortran_stop_numeric'
> reference to `_gfortran_st_write'
> reference to `_gfortran_transfer_character'
> collect2: ld returned 1 exit status
It would seem to me that your copy of libblas was built missing the -lgfortran
switch in the Makefile (it's not linking to the gfortran library).  i.e. your
BLAS package is broken.   have a look at libblas.so with 'ldd' and/or 'nm -D'
Hamish
      ____________________________________________________________________________________
Be a better sports nut!  Let your teams follow you
with Yahoo Mobile. Try it now.  http://mobile.yahoo.com/sports;_ylt=At9_qDKvtAbMuh1G1SQtBI7ntAcJ
