[GRASS-user] d.polar strange behavior when using MASK
Glynn Clements
glynn at gclements.plus.com
Wed Oct 3 09:11:30 EDT 2007
Stefano Costa wrote:
> I was trying to use d.polar on an aspect map.
> I've been able to produce EPS output w/o any problem, except when using a
> raster MASK. My mask leaves out many (about 95%) of the cells in the
> whole region. Without MASK it took 2 minutes for d.polar to complete.
> If I run d.polar on the same map w/ this MASK, I get no results, even
> though I've been waiting (patiently :-) for more than 1 hour.
> Any suggestion about this problem? I saw d.polar is a shell script, thus
> possibly slow, but I'm confused because on a larger number of cells it
> works well.
Try using "sh -x", e.g.
sh -x `which d.polar` map=...
That should provide some clues as to where it's hanging.
