[GRASS-user] d.polar strange behavior when using MASK
Glynn Clements
glynn at gclements.plus.com
Fri Oct 5 10:26:20 EDT 2007
Stefano Costa wrote:
> > Due to g.parser, you have to actually edit the d.polar script and add -x
> > to the first line (in GRASS: edit $GISBASE/scripts/d.polar).
> > change:
> > #!/bin/sh
> > to:
> > #!/bin/sh -x
> Hi Markus,
> sorry I didn't notice your message before.
> The complete output is:
> [Raster MASK present]
> GRASS 6.2.1 (donetta):~ > d.polar map=aspect.5m at PERMANENT undef=0
> eps=built.eps+ '[' -z /usr/lib/grass ']'
> + '[' map=aspect.5m at PERMANENT '!=' @ARGS_PARSED@ ']'
> + exec g.parser /usr/lib/grass/scripts/d.polar map=aspect.5m at PERMANENT
> undef=0 eps=built.eps
> + '[' @ARGS_PARSED@ '!=' @ARGS_PARSED@ ']'
> ++ basename /usr/lib/grass/scripts/d.polar
> + PROG=d.polar
> ++ which awk
> + '[' '!' -x /usr/bin/awk ']'
> + '[' -n built.eps ']'
> + '[' 0 -eq 1 ']'
> + '[' 0 -eq 1 ']'
> + unset LC_ALL
> + LC_NUMERIC=C
> + export LC_NUMERIC
> ++ g.tempfile pid=27616
> + TMP=/home/steko/grassdata/donetta/steko/.tmp/cycnus/27616.0
> + '[' 0 -ne 0 ']'
> + '[' -z /home/steko/grassdata/donetta/steko/.tmp/cycnus/27616.0 ']'
> + r.stats -1 aspect.5m at PERMANENT
> r.stats: 100%
> ++ wc -l /home/steko/grassdata/donetta/steko/.tmp/cycnus/27616.0_raw
> ++ awk '{print $1}'
> + TOTALNUMBER=3354642
> + echo 'Calculating statistics for polar diagram... (be patient)'
> + cat /home/steko/grassdata/donetta/steko/.tmp/cycnus/27616.0_raw
> + grep -v '^*$'
> + grep -v '^0$'
> + awk '{printf "%d\n", int($1 + .5)}'
> + sed 's+^360+0+g'
> ... and it hangs at this point.
Strange. How large is the 27616.0_raw file? Does anything get written
to the 27616.0_binned file? What happens if you execute the command
manually, i.e.:
GIS_OPT_UNDEF=0
cat ${TMP}_raw | grep -v '^*$' | grep -v "^${GIS_OPT_UNDEF}$" | awk '{printf "%d\n", int($1 + .5)}' | sed 's+^360+0+g' > ${TMP}_binned
