[GRASS-user] Mac OS X startup problem
Kirk Wythers
kwythers at umn.edu
Fri Oct 5 19:52:35 EDT 2007
Mark,
Not sure which binary you installed. Great instructions can be found
here:
http://www.kyngchaos.com/software/unixport/
Not not forget to install Williams "frameworks" before you run either
GRASS installers (62. or 6.3). My advice is trash your old binary,
install the frameworks then reinstall.
Good luck,
Kirk
On Oct 5, 2007, at 6:20 PM, Ruddy M wrote:
> Hello all,
> I'm new to GRASS and am having problems getting going. Very
> grateful if anyone could advise.
> Just downloaded GRASS 6.2.1 for MacBook running Mac OS X 10.4.2.
> Install ok. Got the startup splash screen ok. Looks slightly
> different to how described at http://wwwamb.bologna.enea.it/
> forgrass/tips.htm, but followed instructions here on creating a new
> Location. I don't have a Georeference file so clicked the 'EPSG
> codes' button. In the pop up box Name of new location, and Path to
> new location and Path to EPSG-codes file are ok. I then Browse
> 'EPSG code number of projection', choose my EPSG code and enter it
> in the available field. Click 'Define new location' and get the
> following error popup.
> Error: child process exited abnormall...
> Details :
> child process exited abnormally
> while executing
> "exec -- $env(GISBASE)/etc/grass-xterm-wrapper -e $env(GISBASE)/etc/
> make_location_epsg.sh $epsg_code $epsgLocation $locpath >@stdout
> 2>@stderr"
> invoked from within
> ".optPopup.submit invoke"
> ("uplevel" body line 1)
> invoked from within
> "uplevel #0 [list $w invoke]"
> (procedure "tk::ButtonUp" line 23)
> invoked from within
> "tk::ButtonUp .optPopup.submit"
> (command bound to event)
> Am I missing something? Am I going about startup correctly? Any
> help greatly appreciated.
> Best Wishes
> Mark Ruddy
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20071005/aa2bd328/attachment.html
