[GRASS-user] r.sun with shadowing effects
Markus Neteler neteler at itc.it
Mon Oct 8 16:10:37 EDT 2007
HamishB wrote:
> Odoardo Zecca wrote:
>> I need to calculate the solar radiation (with r.sun) of a relatively
>> small
>> area taking into account the shadowing effect of reliefs spread in a much
>> larger area. In order to be able to get a high resolution map of the area
>> of
>> interest, or even just the values relatives to some particular sites, is
>> there a way to avoid the long computational time needed for areas I'm not
>> interested in?
> I don't think so (at least not without modifying the code), but I would be
> interested in the same functionality.
There is some hope: from JRC I received an unpublished r.sun2 + r.horizon
which separates (the slow) horizont calculation from the (much faster)
energy
calculations. Run r.horizon once and then r.sun2 as often as you need.
I'll check if I can put it into GRASS Addons SVN.
Markus
View this message in context: http://www.nabble.com/r.sun-with-shadowing-effects-tf4569151.html#a13103922
Sent from the Grass - Users mailing list archive at Nabble.com.
