[GRASS-user] Artefacts when interpolating DTM from Contour Lines
with v.surf.rst
Andreas Neumann
a.neumann at carto.net
Tue Oct 9 01:08:50 EDT 2007
yes, I am changing various values, including dmin. I get different sizes
of the rectangular artefacts, but they never really disappear,
regardless of the values I used. I still hope I can find a better
parameter combination where the artefacts aren't visible.
Andreas
Andrea Ricci wrote:
> Andreas Neumann wrote:
>> Hello,
>> I am trying to interpolate a raster DTM from contour lines. I like the
>> results from v.surf.rst, however, this algorithm, at least with my
>> settings seams to generate rectangular artefacts in the resulting DTM.
>> See
>> a hillshade of my result at
>> http://www.carto.net/neumann/temp/hs_dtm_tension5_smooth2.png - if it
>> weren't for these artefacts I would like the results very much.
>> Here are the parameters I used:
>> v.surf.rst input=hl layer=1 zcolumn=elev_m dmax=10 dmin=0.5
>> elev=dtm_tension5_smooth2 zmult=1.0 tension=5 smooth=2 segmax=40
>> npmin=300
>> --overwrite
>> The idea is to get a smooth, not too detailed DTM, hence the small
>> tension
>> and higher smooth values.
>> Are there any parameters or postprocessing steps that would help me
>> remove
>> these rectangular artefacts? Or alternatively, are there better
>> methods to
>> interpolate DTMs from contour lines?
>> Thanks for any ideas,
>> Andreas
> Try with increasing dmin= 2 or try with other values. Normally, in case
> of visible segmentation, this value must be increased.
> hope that's helpful
> Andrea Ricci
Andreas Neumann
Böschacherstrasse 6
CH-8624 Grüt (Gossau ZH)
Switzerland
Phone: ++41-44-2736668
Email: a.neumann at carto.net
Web: http://www.carto.net/neumann/
SVG Examples: http://www.carto.net/papers/svg/samples/
SVG.Open: http://www.svgopen.org/
