[GRASS-user] create a xy location with g.proj
Hamish
hamish_nospam at yahoo.com
Wed Oct 10 02:09:42 EDT 2007
> Peter Löwe wrote:
> > does anybody have an example how to create a xy-location using g.proj
> > -c ?
> > Calling up g.proj from within a xy-location using the -j/-w flags (to
> > create output in wkt/proj format) results in the info "xy location
> > (unprojected)". This doesn't really help.
Michael Barton wrote:
> AFAIK, you cannot create an xy location using g.proj. g.proj is for
> creating projected locations. xy is not projected. When I wanted to
> create an xy location for the new wxPython location wizard, I had to
> code it myself. That said, it's not hard to create the WIND, etc files
> for an xy location.
If this doesn't exist, then we should look at adding the functionality.
for example:
g.proj -c location="newloc" wkt=none
or
g.proj -c location="newloc" wkt=XY
or
g.proj -c location="newloc" wkt=unprojected
then in g.proj we test for that string and reroute as needed.
Hamish
