[GRASS-user] Export of GeoTIFF
Michael Barton
michael.barton at asu.edu
Wed Oct 10 19:31:32 EDT 2007
You can get GRASS data into ArcView/ArcGIS much more simply than this.
Vector: use v.out.ogr to export to a shape file
Raster: use r.out.arc OR r.out.gdal to export to an ESRI ASCII grid file
Michael
On 10/10/07 3:56 PM, "al furqon lebo" <alf_lebo at yahoo.com> wrote:
> GRASS Data To ArcView
> This document will show the procedure to export GRASS raster and vector data
> to
> ArcView.
> GRASS Vector Data to ArcView 2.1/3.0
> 1) In GRASS use the v.out .ascii command on the vector file you wish to
> export.
> 2) In GRASS use the v.out.dxf command on the ascii file you created above.
> When
> GRASS prompts you for a dxf file name, type in the name with extension(i.e.
> soils.dxf). The .dxf extension will be needed for ArcView.
> Please note that dxf files can only be displayed in ArcView 2.1(MS Windows)
> and
> ArcView 3.0(UNIX and MS Windows).
> 3) To display the dxf file in ArcView you first need to open a VIEW then add a
> theme(Feature Data Source). The dxf file should be selectable on the screen.
> Open
> the dxf file. You have to convert the dxf file to a shapefile in order to
> change
> projection etc.
> GRASS Raster Data To ArcView 2.1/3.0
> This procedure will georeference a raster image within ArcView!
> 1) In GRASS use the r.out.tiff command on the Raster file you wish to export.
> Use
> defaults for the command! In particular DO NOT use the LZW compression! This
> may make your file unreadable in ArcView. The GRASS generated TIFF file should
> have a tiff extention(i.e. photo1.tif)
> 2) After making the TIFF file goto your "cellhd" sub-directory!
> 3) Cat the raster cellhd file you exported! You will use the information in
> this file to
> build a world file. A world file is a ascii file ArcView uses to georeference
> information
> for the TIFF file you created. With the world file your TIFF file will be
> georeference in
> ArcView.
> 4) Start a vi session, name the file the same as your TIFF file except with a
> different
> extention! Use the extention .tfw (i.e. photo1.tfw ). You will enter six lines
> of
> information in your vi session. You can use this file as a base for future
> world file.
> Below is the possible contents of a typical world file.
> 10.0
> 0.0
> 0.0
> -10.0
> 590005
> 4927995
> Below is the possible contents of a typical GRASS cellhd file.
> proj: 1
> zone: 16
> north: 4928000.000000
> south: 4914000.000000
> west: 590000.000000
> east: 609000.000000
> n-s resol: 10.000000
> e-w resol: 10.000000
> format: 1
> compressed: 0
> Below is the information you will need to create the above world file(tfw).
> Please note
> that the world file contains information in your GRASS cellhd file!
> Information on the
> world file can be found in ArcView 3.0 manual on page 301.
> World File GRASS Cellhd File Description
> 10.0 "e-w resol:" Size of pixel in x direction.
> 0.0 N\A Rotation term for row(usually 0).
> 0.0 N\A Rotation term for column(usually 0).
> -10.0 "n-s resol:" Size of pixel in y direction(- sign is needed!)
> 590005 "west" + 1/2 "e-w resol" The x coordinate of pixel in upper left
> corner. *
> 4927995 "north" - 1/2 "n-s resol" The y coordinate of pixel in upper left
> corner. *
> Pixel 1,1 * ArcView georeferences the center of the pixel while GRASS
> uses the NW edge in the cellhd file. Thus a slight adjustment is
> needed to correctly georeference a TIFF file in ArcView. For these
> lines you need to add one half the pixel resolution(west) and subtract
> one half the pixel resolution(north).
> 5) Place your TIFF and world file in the same directory. These files now can
> be used
> in ArcView and should be georeferenced correctly!.
> A sample world file call be found at the NCG FTP Site! The NCG FTP is listed
> below.
> ftp.ftw.nrcs.usda.gov (goto the /outgoing directory! and get the file
> "base.tfw")
> If You have any questions please contact me at your convenience.
> Tony Kimmet
> (817)-334-5212 x3062
> tkimmet at ftw.nrcs.usda.gov
> Michael Barton <michael.barton at asu.edu> wrote:
>> Re: [GRASS-user] Export of GeoTIFF ESRI needs special GeoTiff options to
>> be enabled. These are documented on the r.out.gdal manual page--near the
>> bottom where I missed them too awhile back.
>> Michael
>> On 10/9/07 11:58 PM, "christian.braun at tudor.lu" <christian.braun at tudor.lu>
>> wrote:
>>> Dear list,
>>> I have serious problems exporting GRASS DCELL rasters to GeoTIFF.
>>> I used r.out.gdal with type=Float32 and set the compression to LZW.
>>> What I got later on in ArcView 3.3 is pure noise fort he picture and in
>>> ArcGIS 9.2 I get some strange results.
>>> The NULL values of the picture get a cryptic code like -1#QUAN1 and if
>>> there are pixels with value 0 they become NoData in ArcGIS.
>>> I need to have them as GeoTIFFs for the easy im- and export. I am aware
>>> that I can also use r.out.ascii but then I have to do an import procedure in
>>> ArcGIS. For nearly 1000 images that is a bit hard to do.
>>> Any hints for the export options?
>>> Thx in advance,
>>> Christian
>>> _________________________________________
>>> Dipl. Geogr. Christian Braun
>>> Tel: +352- 425991-608
>>> Mobil: +49-179-6845896
>>> Mail: christian.braun at tudor.lu
>>> Resource Centre for Environmental Technologies,
>>> Public Research Centre Henri Tudor,
>>> Technoport Schlassgoart,
>>> 66 rue de Luxembourg,
>>> P.O. BOX 144,
>>> L-4002 Esch-sur-Alzette, Luxembourg
>> __________________________________________
>> Michael Barton, Professor of Anthropology
>> Director of Graduate Studies
>> School of Human Evolution & Social Change
>> Center for Social Dynamics & Complexity
>> Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
>> <http://www.public.asu.edu/%7Ecmbarton>
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
> your sincerely
> alf
> -_-____02053
> Building a website is a piece of cake.
> Yahoo! Small Business gives you all the tools to get online.
> <http://us.rd.yahoo.com/evt=48251/*http://smallbusiness.yahoo.com/webhosting/?
> p=PASSPORTPLUS>
Center for Social Dynamics and Complexity
phone: 480-965-6213
fax: 480-965-7671
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20071010/8570006b/attachment.html
