[GRASS-user] v.extrude: advice on generating 3D building
Jachym Cepicky
jachym.cepicky at gmail.com
Wed Oct 17 02:29:16 EDT 2007
height means hight of the buildings. All buildings can have same height
(height=10) or the height of each building is stored in database
(hcolumn=building_height)
elevation option stays for placement of the building upon the digital
elevation model.
so, in your case, you have to:
1 - prepare DEM *without* building footprints
2 - transfer building height parameter from raster map to attribute
table of the vector file
3 - run v.extrude as
v.extrude ... hcolumn=column_with_building_height \
elevation=lidar_dem_without_buildings
hope it helps
jachym
cheg01 at comcast.net píše v St 17. 10. 2007 v 04:31 +0000:
> I am trying to use v.extrude to generate buildings of varying height. I
> have a vector file with all of the building outlines and I have a
> raster file that contains high resolution height data extracted from
> LIDAR files. I don't understand the function of v.extrude. I tried
> specifying the raster file name in the "elevation=" option but I get
> an error that says I have to either use a constant height in "height="
> or specify an attribute table column with height data in "hcolumn=".
> What does the "elevation" option do? Any suggestions on easy ways to
> populate a height data column from a raster file?
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Jachym Cepicky
e-mail: jachym.cepicky at gmail.com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20071017/9ef9c903/attachment.bin
