[GRASS-user] 3D Buildings
Jachym Cepicky
jachym.cepicky at gmail.com
Fri Oct 19 01:49:19 EDT 2007
cheg01 at comcast.net píše v Pá 19. 10. 2007 v 00:43 +0000:
> I am trying to generate a model very much like the screenshot of Trento
> on the Grass home page using data for the city of Seattle. I have
> building outlines and heights in a vector map and accurate elevation
> data in a raster file. I have used v.extrude to construct the
> buildings. When I try to plot them in nviz, I get odd disjointed
> floating surfaces rather than the solid looking 3D objects objects in
> the Trento example.
note: NVIZ has problems with concave shapes, like
you can use paraview for 3D data displaying as well
> The extruded vector coverage has only faces, no
> lines, areas, or centroids. Is that normal?
faces are to be understood as "3D areas", their centroids are "kernels".
yes, v.extrude generates only faces
> I tried extruding both
> with and without the "trace" flag set.
this only causes, that the "roofs" of building will "copy" the
elevation. Otherwise, they remain flat.
> What commands were used to create the beautiful model of Trento? Was it something other than v.extrude and nviz?
Markus knows more ..
but I would say, something like
1 - prepare map with areas (no lines) of building footprints
2 - each area has to have centroid
3 - update building height in the map attribute table
4 - run v.extrude like
v.extrude in=building_areas out=builidngs3D elevation=your_dem
hcolumn=height_column_in_attribute_table
hope it helps
Jachym
Jachym Cepicky
e-mail: jachym.cepicky at gmail.com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20071019/33216297/attachment.bin
