[GRASS-user] RE: [GRASS-dev] v.in.ogr parameter displays as
optional instead of required
Patton, Eric
epatton at nrcan.gc.ca
Wed Oct 24 14:54:58 EDT 2007
Thanks for clearing that up Martin.
~ Eric.
-----Original Message-----
From: Martin Landa [mailto:landa.martin at gmail.com]
Sent: Wed 10/24/2007 3:39 PM
To: Patton, Eric
Cc: grassuser at grass.itc.it; grass-dev at grass.itc.it
Subject: Re: [GRASS-dev] v.in.ogr parameter displays as optional instead of required
2007/10/24, Patton, Eric <epatton at nrcan.gc.ca>:
> In v.in.ogr, the output parameter shows as 'optional' in the gis.m gui (6.3.cvs), when it's actually required:
> $ v.in.ogr dsn=. type=point layer=Matthew_2007006_Nav_JD127_MinasChannel
> ERROR: Required parameter <output> not set
> Probably a simple swapping of words is all that's required?
Parameter 'output' is not required by default because of -l or -f
flag. It is required only if you are going to import data.
Martin
> ~ Eric.
> grass-dev mailing list
> http://grass.itc.it/mailman/listinfo/grass-dev
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
