[GRASS-user] r.to.vect peculiarity
Martin Wegmann wegmann at biozentrum.uni-wuerzburg.de
Fri Oct 26 06:14:38 EDT 2007
Hello,
I did a svn update and wanted to run r.to.vect as usual but when it failed I
received this info:
r.to.vect --h
Description:
 Converts a raster map into a vector map layer.
Keywords:
 raster
Usage:
 r.to.vect [-svzbq] [column=name] output=name feature=string
   [--overwrite] [--verbose] [--quiet]
Flags:
  -s   Smooth corners
  -v   Use raster values as categories instead of unique sequence (CELL only)
  -z   Write raster values as z coordinate. Table is not created. Currently
supported only for points.
  -b   Do not build vector topology (use with care for massive point export)
  -q   Quiet - Do not show progress
 --o   Allow output files to overwrite existing files
 --v   Verbose module output
 --q   Quiet module output
Parameters:
   column   Name of attribute column
   output   Name for output raster3d map
  feature   Feature type
            options: point,line,area
            default: line
How do I convert my raster to vector now?
Or is this an intermediate state of r.to.vect change?
with confused regards, Martin
