[GRASS-user] How can I place multiple ps.map maps in one graphic?
Hamish
hamish_nospam at yahoo.com
Thu Oct 25 06:47:34 EDT 2007
Thomas wrote:
> I see from the documentation that ps.map allows only one raster map per
> run of ps.map. But what if I want to show a panel of say, 4 different
> maps (each with it's own raster map) in one graphic - for comparison
> purposes. Could I, for instance, generate 4 eps files from ps.map and
> have ps.map lay them out?
Eric wrote:
> Yes your approach is correct; get ps.map to compose the eps files, then
> insert each eps into your master output file.
I have created a new wiki page explaining the trick.
http://grass.gdf-hannover.de/wiki/Ps.map_scripts
Also of note, I have added to the wiki:
- Willem's instructions for making the Norway geology screenshot.
http://grass.gdf-hannover.de/wiki/Psmap_moldefjord_example
- New links to GFOSS.it's north arrows, meteorology, geology, and trees symbol
sets. Also added are instructions on how to use inkscape from the command
line to convert SVG to EPS (for use with ps.map).
http://grass.gdf-hannover.de/wiki/IconSymbols#Other_contributions
Still needed: someone to write a little script to convert EPS images into
GRASS's display symbol format. It would be nice if the same converter could
create d.graph drawing commands as well (this part is probably pretty easy).
i.e., it would be good to be able to display EPS in an xmon and create symbols
in ways other than by hand.
Hamish
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
