[GRASS-user] Question about MAPSET permissions with a GRASS script
Thomas.Adams at noaa.gov Thomas.Adams at noaa.gov
Mon Oct 29 09:06:46 EDT 2007
Glynn,
Thanks, but I don't want to break that feature in GRASS. I suppose I was hoping that someone might have a suggestion as to how I might set an environment variable or do something in my script that would set the login ID to 'oper' that GRASS would recognize as legitimate. Someone I work with suggested that some use of 'expect' might work; so, I am playing with that approach.
Regards,
Tom
----- Original Message -----
Date: Sunday, October 28, 2007 11:12 pm
Subject: Re: [GRASS-user] Question about MAPSET permissions with a GRASS script
> Thomas Adams wrote:
> > I have written a GRASS shell script for Linux that works
> perfectly well
> > except for one thing. Anyone who runs it from their login ID must
> be
> > able to run the script, which they initiate manually. The MAPSET
> is
> > generic, called 'oper' � we have an 'oper' Linux login. What
> happens is
> > that unless I login or 'su' to 'oper', the script fails with:
> > ERROR: MAPSET oper � permission denied
> > etc.
> > The process involves (among other things) reading in point data
> using
> > v.in.ascii and spatially interpolating it to a raster.
> > I have tried a number of things to set the GRASS permissions to
> allow
> > universal access to the 'oper' MAPSET as well as trying to export
> the
> > USER variable, etc. Nothing seems to work. Does anyone have a
> > suggestion?
> GRASS requires that you own the current mapset.
> If you want to avoid this, you need to remove the check from
> G__mapset_permissions() in lib/gis/mapset_msc.c.
> Glynn Clements <glynn at gclements.plus.com>
