[GRASS-user] sql and postgis
Moritz Lennert
mlennert at club.worldonline.be
Mon Oct 29 09:33:40 EDT 2007
On 25/10/07 17:20, Gustavo Martinez wrote:
> Hi all,
> I am using GRASS 6.3 RC1 compiled from source. I have a big table (2 million
> points) in Postgresql/Postgis that I can map with v.external. The problem is
> when I try to select a subset of the data. I am using gis.m and when I run
> the command:
> d.vect map=monitoreo at PERMANENT color=0:0:0 lcolor=0:0:0 fcolor=170:170:170
> display=shape type=point icon=basic/circle size=5 layer=1 lsize=8 xref=left
> yref=center llayer=1 {where=vel<4}
> I get the following error:
> ERROR 1: ERROR: error de sintaxis en o cerca de «FROM»
> LINE 1: SELECT FROM monitoreo WHERE vel<4
> DBMI-OGR driver error:
> Cannot select:
> Any clues?
What does v.db.connect -p monitoreo show ?
Does database access work for v.external maps just as it does for
imported maps ?
Moritz
