[GRASS-user] sql and postgis
Moritz Lennert
mlennert at club.worldonline.be
Mon Oct 29 11:53:20 EDT 2007
On 29/10/07 15:17, Gustavo Martinez wrote:
> El Monday 29 October 2007 10:33:40 escribió:
>> On 25/10/07 17:20, Gustavo Martinez wrote:
>>> Hi all,
>>> I am using GRASS 6.3 RC1 compiled from source. I have a big table (2
>>> million points) in Postgresql/Postgis that I can map with v.external. The
>>> problem is when I try to select a subset of the data. I am using gis.m
>>> and when I run the command:
>>> d.vect map=monitoreo at PERMANENT color=0:0:0 lcolor=0:0:0
>>> fcolor=170:170:170 display=shape type=point icon=basic/circle size=5
>>> layer=1 lsize=8 xref=left yref=center llayer=1 {where=vel<4}
>>> I get the following error:
>>> ERROR 1: ERROR: error de sintaxis en o cerca de «FROM»
>>> LINE 1: SELECT FROM monitoreo WHERE vel<4
>>> DBMI-OGR driver error:
>>> Cannot select:
>>> Any clues?
>> What does v.db.connect -p monitoreo show ?
>> Does database access work for v.external maps just as it does for
>> imported maps ?
>> Moritz
> Moritz,
> the result of v.db.connect monitoreo -p is:
> Vector map <monitoreo> is connected by:
> layer <1> table <monitoreo> in database <PG:host=localhost dbname=pesca-new
> user=postgres> through driver <ogr> with key <>
There's the problem: 'with key <>'. GRASS does not know how to link the
geographical data (the map) to the attribute data. This is where the
SELECT FROM comes from, i.e., nothing to select.
As I said, I'm not sure that a map linked into GRASS with v.external can
be used for database queries. Also don't know what the ogr driver supports.
You could try to relink the map directly to the postgresql table with
something like
v.db.connect -o map=monitoreo driver=pg database="host=localhost
dbname=pesca-new" table=monitoreo key=XXX
where XXX is the column that contains the identifiers of the
geographical objects in your map.
Moritz
