[GRASS-user] sql and postgis
Moritz Lennert
mlennert at club.worldonline.be
Tue Oct 30 14:00:30 EDT 2007
On 30/10/07 18:28, Gustavo Martinez wrote:
> El Monday 29 October 2007 12:53:20 escribió:
>>> Moritz,
>>> the result of v.db.connect monitoreo -p is:
>>> Vector map <monitoreo> is connected by:
>>> layer <1> table <monitoreo> in database <PG:host=localhost
>>> dbname=pesca-new user=postgres> through driver <ogr> with key <>
>> There's the problem: 'with key <>'. GRASS does not know how to link the
>> geographical data (the map) to the attribute data. This is where the
>> SELECT FROM comes from, i.e., nothing to select.
>> As I said, I'm not sure that a map linked into GRASS with v.external can
>> be used for database queries. Also don't know what the ogr driver supports.
>> You could try to relink the map directly to the postgresql table with
>> something like
>> v.db.connect -o map=monitoreo driver=pg database="host=localhost
>> dbname=pesca-new" table=monitoreo key=XXX
>> where XXX is the column that contains the identifiers of the
>> geographical objects in your map.
>> Moritz
> I've tried the following command:
> v.db.connect -o map=monitoreo driver=pg database=pesca-new table=monitoreo
> key=idmonitoreo layer=1
> and it gave me the following:
> pg driver: column 'fecha', type 1184 is not supported
> pg driver: column 'fch_local', type 1184 is not supported
> pg driver: PostGIS column 'geom', type 'geometry' will not be converted
> The table <monitoreo> is now part of vector map <monitoreo> and may be deleted
> or overwritten by GRASS modules
> However, if I tgry again
> v.db.connect monitoreo -p the key field is still empty.
What is the output of v.db.connect -p ?
I'm not sure I can help you any further, but my guess would be that
there is a difference in the handling of maps linked via v.external
compared to maps which are imported into GRASS...
Moritz
