[GRASS-user] Re: DGN: LoS [was] grass
H.S.Rai
hardeep.rai at gmail.com
Wed Oct 31 03:34:04 EDT 2007
On Wednesday 24 October 2007, ec.jkd at tpcsed.com wrote:
> > On a contour map i want to plot two points A an B .The requirment is to
> > know if point A has a line of sight with point B. For this i started with
> > r.contour but this only gives me ontour of pheripheral i.e only the outline
> > and not the actual contour map with different heights. Now what i want from
> > you is firslty how shoulsd i produce first contour map and then find line
> > of sight.
Import your "56k.gdn":
v.in.ogr -z dsn=56k.dgn output=dgn
Change region as per your requirement:
g.region vect=dgn
or
g.region n=22000 s=-2400 e=11000 w=-22000
Convert vector to raster:
v.to.rast input=dgn output=dgnRas use=attr column=Level
Produce DEM:
r.surf.contour input=dgnRas output=dgnDTM
r.los give you viewshed, not visibility between two point, as such.
You may also try d.profile
All the dest,
H.S.Rai
http://hs.raiandrai.com/
