[GRASS-user] sql and postgis
Gustavo Martinez gumartin at mecon.gov.ar
Wed Oct 31 08:33:13 EDT 2007
El Tuesday 30 October 2007 18:06:50 Markus Neteler escribió:
> Gustavo Martínez wrote:
> > I've tried the following command:
> > v.db.connect -o map=monitoreo driver=pg database=pesca-new
> > table=monitoreo key=idmonitoreo layer=1
> >  and it gave me the following:
> > pg driver: column 'fecha', type 1184  is not supported
> > pg driver: column 'fch_local', type 1184  is not supported
> > pg driver: PostGIS column 'geom', type 'geometry'  will not be converted
> I have checked the PG type:
> grep 1184 /usr/include/pgsql/server/catalog/pg_type.h
> DATA(insert OID = 1184 ( timestamptz PGNSP PGUID        8 f b t \054 0  0
> timestamptz_in timestamptz_out timestamptz_recv timestamptz_send - d p f 0
> -1 0 _null_ _null_ ));
> #define TIMESTAMPTZOID  1184
> cd db/drivers/postgres/
> grep TIMESTAMP *
> create_table.c:            case DB_SQL_TYPE_TIMESTAMP:
> db.c:       type = PG_TYPE_TIMESTAMP;
> describe.c:     case PG_TYPE_TIMESTAMP:
> describe.c:         *sqltype = DB_SQL_TYPE_TIMESTAMP;
> fetch.c:            case PG_TYPE_TIMESTAMP:
> globals.h:  PG_TYPE_TIMESTAMP, /* timestamp */
> AFAIK the TIMESTAMPTZ type is yet undefined (with timezone).
> The question is if DB_SQL_TYPE_TIMESTAMP is compliant to it
> so that TIMESTAMPTZ can be mapped in globals.h
> Markus
I've changed the TIMESTAMPTZ type by TIMESTAMP in the PG table. when I do
v.db.connect now it says
The table <monitoreo> is now part of vector map <monitoreo> and may be deleted
or overwritten by GRASS modules
If I now try
v.info -c map=monitoreo at PERMANENT layer=1
the result is
Unable to open vector map <monitoreo at PERMANENT> on topology level 2
So I think the problem with the sql query  is that GRASS don't know about the
columns of the PG table.
I don't know if that is the way GRASS handles the external layers.
Gustavo
Lic. Gustavo Martínez
Gestión de Pesquerías
Sub Secretaría de Pesca de la Nación
Paseo Colón 982, Anexo Jardín Pesca
Tel: (54) 11 43492165
Buenos Aires, República Argentina
“Que la tierra se vaya haciendo camino ante tus pasos,
que el viento sople siempre a tus espaldas,
que el sol brille cálido sobre tu cara,
que la lluvia caiga suavemente sobre tus campos y,
hasta tanto volvamos a encontrarnos,
que Dios te lleve en la palma de su mano.”
