[GRASS-user] Re: grass.bat script for Cygwin GRASS 6.2.2-1
Tue Sep 4 18:08:07 EDT 2007
Luigi Ponti wrote:
> >>    p.out.vrml.html
> > should be there:
> > -rw-r--r-- glynn/None     3430 2007-07-17 18:40:00 usr/local/grass-6.2.2/docs/html/r.out.vrml.html
> OK, but I don't have it: just double checked the folder. Also the binary
> in C:\cygwin\usr\local\grass-6.2.2\bin is only 1KB and contains just the
> following line
>     !<symlink>r.out.vrml
This is what a Cygwin symlink looks like if you open it in a Windows
program (e.g. Notepad).
Note that p.out.vrml is just a symlink to r.out.vrml (the name has
changed).
